FS: 2x Alpine MRP-M500 - $150 each / $250 BOTH
Shipped in Continental 48 states.
This amplifier has been tested on the bench to operate normally but there is NO FURTHER WARRANTY IMPLIED OR EXPRESSED beyond that this amp will work when you receive it.
NO TRADES - Do not PM me with "What is the lowest you will take" - MAKE AN OFFER if you have one.
# mono subwoofer car amplifier
# 300 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
# variable low-pass filter (50-200 Hz, 24 dB/octave)
# variable bass boost (0-12 dB at 50 Hz)
# subsonic filter (15 Hz, 24 dB/octave)
# Class D amp with MOSFET power supply
# CEA-2006 compliant
# STAR Topology (minimizes internal noise and prevents ground interference)
# speaker- and preamp-level inputs
# gold-plated screw terminals
# fuse rating: 30A x 2
# 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
# 10-11/16"W x 2-7/16"H x 9-9/16"D
ONE AMPLIFIER HAD THE MOUNTING FEET REPAIRED. You cannot see this once the top covers are mounted.
Edited by sundownz
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
This topic is now closed to further replies.
