I Give Up, I Need Help
whenever i try to set my gains with a dmm i can never get the voltage i am supposed to. i was just trying to set my 2 saz1500's strapped. i need 77v. turned the gain up all the way and only got 59.1v. hu volume was at 50/62. now here's the kicker... if i turn the volume up more than 50 the voltage goes down. same thing if i raise the sub level on the hu.
ive tried using a differant dmm on a differant amp in the past and i couldnt seem to get the voltage up to where i needed it either. i didnt try going all the way up on the gain though.
any ideas on why im not getting high enough voltage?
i just realized what it might be... since its 2 amps strapped it uses the + outputs from both amps. master + goes to sub + and slave - goes to sub -. i used the wires that go into the subs so i used the + from both amps. is that the problem? ill have to test it again tomorrow
got a bass knob hooked up to the amps? is it turned all the way up? do the amps have a voltage selector like the clarion amps do? is it set to 2-6v?
Edited by eliassami5
91' Jeep Cherokee - The Heep
Just Empty Every Pocket
96' Volvo 960 - The B◘x
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
did you but one in each amp? and did you connect the negative terminals when doing it?
- is connected from one amp to the other.
gain knob was not connected. no voltage selector.
on sundowns you take the - from subs and connect them to + on slave amp and then connect the amps negative terminals
correct, that is what i did. but when you test gains with a dmm should you be reading the + from both amps?
stick + probe into master and - probe into slave and adjust the gain on master only
into the + on both amps correct???
Edited by skittlesRgood
  • Who's Online   1 Member, 0 Anonymous, 1131 Guests (See full list)
