4 Soundstream 12's In A Standard Cab Dime
Got the hardware.
The Socket heads in the sub
Corners
Circle Jig I made for cutting my baffles
Ill add the rest of the build pics a little bit later.
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
Front baffle cut
Using the jig
Trim baffle to recess the subs.
Test fitting the sub, Looks really good to me.
Drilled the holes for the Tee-nuts & checked the alignment.
Current System:
Pioneer 6900 HU
Bass:
I hope your painting this bitch again because the gap you left on the baffle and the sub gasket is way to tight for anything else! Looking good again and I'm tuned in once again :hairtrick:
The Shoe Maker without shoes!
All 32 Tee's in
Couldnt resist :wub:
Dowels in
Cutting the dowels with an end mill.
Messing with the front baffle, getting it ready.
More resin
Current System:
Pioneer 6900 HU
Bass:
So I took pictures of all the resin corners but they all look the same so ima skip them.
Speaker terminals, 1/4"
Carriage bolts to hold it to the floor.
Terminals, washers, ntus & all the wire.
So far...
All thread in
& colored.
Wired up
& since I totally forgot heres a picture of my rear view mirror missing, it fell off :)
Set the box in for the first time & it fits perfectly.
Bolted it down...
Started wiring them up & getting them bolted in too.
Done!
It comes out to about 2.6 cubes after displacement, I thought it would sound pretty good & get fairly loud, but perhaps I made it too small? They hit pretty hard but my voltage is getting crazy low. & before my truck seemed loudest with 1 window down or 1 door open, other side sealed. Now it gets loudest with both windows down about 2/3 of the way. Any thoughts on this?
Current System:
Pioneer 6900 HU
Bass:
:hairtrick: < I wish.
Something is really messed up all of a sudden. I dont think its even doing a 140 which is sad bc my first box for these did a 141.9.
I need help.
Current System:
Pioneer 6900 HU
Bass:
  • 3 years later...
Yesterday I started teh new box.
Routing out the back wall for airspace. every little bit counts.
Matted & resined corners. Should be strong.
Let me know what you guys think so far!
Are you predrilling? that makes a huge difference. Also, I glue all the boards very thoroughly, rubbing the glue into the wood grain and then adding more to ensure the best seal possible. it's fine to put too much glue, just take your finger and wipe it around, or use a damp cloth and clean it off. Just screws holding mdf wont work for the power you have, the box has to be very strong, I don't even use MDF, I use the heavy 11 ply oak hardwood that's 3/4 in thick. It's not cheap, but it holds screws much better, and is physically heavier, I'll bet it'll sound better too.
Knowledge is the greatest tool in any garage. It's also the most priceless, and most easily shared. icon_nuts.gif
Here's my latest build.
http://www.stevemeadedesigns.com/board/topic/181273-89-c1500-build-log/
