Static Posted May 15, 2009 Report Posted May 15, 2009 Sorry, this is a noob question..i'm brand new to all this. Can someone tell me the difference in this? 250W x 1 @ 4-Ohms RMS 500W x 1 @ 2-Ohms RMS 1000W x 1 @ 1-Ohm RMS
Guest Posted May 15, 2009 Report Posted May 15, 2009 at a 4 ohm load, the amp gives out 250rms, 2 ohms, 500rms, etc
Static Posted May 15, 2009 Author Report Posted May 15, 2009 But whats the difference? sound quality? which one is better?
BAGGEDBIRDS.com Posted May 15, 2009 Report Posted May 15, 2009 they are related, in that if you lower the ohm load on the speaker output of the amp , the amp will put out more watts. Assuming the amp can deliver into that ohm load and not burn up. Ohm load is dictated by the speaker you select. typically the specs of an amp, as far as distortion get higher as the ohm load drop and the qulaity goes down. Can you hear a difference not sure, but it can me measured. For a bass amp i would select speakers that allowed me to maximize its output in watts, or in my mind, your wasting your money. 1st SMD "System of the Month" Feb. 2007 Zapco Studio 500 (2) Zapco Studio 300X Zapco Studio 204 (2) (2) FI 12ssd's w/ copper coils DLS Iridium Tweeters DLS UR2.5 MidRange FI. N.7 Midbass JL Audio TWK 88 Mechman 370A Elite Alternator
Static Posted May 15, 2009 Author Report Posted May 15, 2009 Okay, thanks man. Perfect answer I needed!
ryde2idie Posted May 15, 2009 Report Posted May 15, 2009 the lower resistance you run is also gonna put more of a drain on the electrical components of your car. Quote
