vega87 Posted May 15, 2009 Report Posted May 15, 2009 I would like to undersand what the universal option is for. Because I plan to run my subs at 1 ohm, I would like to know if It would be to my conveniouse to choice this option. Quote
wL<3bass Posted May 15, 2009 Report Posted May 15, 2009 Universal means that it will accept a D1 or D2 coil b/c each coil has a different thickness universal allows you to later recone to a different ohm load if you need......otherwise the motor will be optimized for that coil forever. So basically get universal b/c you never know if you gonna need to change the ohm load. Quote Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
