Made My Own Voltage Module Edit: Video And Pics Up
Trying to figure out which wire is the sense wire for a CS130D. Im interested in trying this out to see how it works. Found a few diagrams but nothing is labeled well.
EDIT: found some good info for GM Guys here
http://oljeep.com/gw/alt/edge_Alternator_Theory.html
Here, I'll end the bickering and tell you what I 've been telling customers for years.
If you have an AD or CS series GM alt, go buy yourself a $.75 1 amp diode and solder it in-line in the sense wire on the alternator plug. It will boost the charging voltage accross the board .6 -.7 Volts. Want higher voltage? just double them up for another .6 - .7 volt increase
If you have a stock 3G or 4G Ford, go buy your self a 6 amp diode for $1.50 at radio shack and solder it in-line in the yellow sense/power wire on the alt plug for a .6 - .7V increase.
(high output versions using an aftermarket rotor will require (2) 6 amp diodes)
Now there's no more mystery. Enjoy.
in regards to the GM CS alts. I got a CS130D. When you say double them up, use 2 1 amp diodes or use a 2 amp diode? Also, which way should the diode be installed? Diodes always confused me for the most part as far as what to hook up where and what not. Im sure i could figure it out, id just hate to be wrong and fuck up my car. I wouldnt run my stock CS130D at an extra 1.2-1.4 but i was just wondering, 15-15.1V sounds nice tho.
  • 1 month later...
edit
DC.jpgDC POWER
  • 1 month later...
added a switch.
14.2-3 factory when the switch is "off"
15.2-3 when the switch is "on"
DC.jpgDC POWER
I'm pretty interested about this diode thing with the GM alts.
what wire do you tap into?
and same with the double up is it 2 1amp diodes or a 2 amp diode?
Wouldnt be thehoe92 without teh purple
its not didoes, that did not work for me. its 2 resistors making a "voltage divider"
DC.jpgDC POWER
if only i remembered all that from my circuits classes.. oh well i got the books somewhere
  • 3 weeks later...
What about for Honda's?? Can I maybe add those diodes like mechman was saying, or does that not work??
Current build:
Pioneer AVH-P3100DVD
Soundstream EQ
RF Components (5 1/4, 6 1/2, 6x9 x 2)
Two Fi-BTL 15's
One RF T1500-1bd Amplifier
T400-4bd
XS Power 608
XS Power D1200
Optima Yellow top 34
Soon to come:
Another RF T1500-1bd
HO Alt
1-6 more XS power 680
Team D.M.V
lol @ this dude...take a chill pill
and to stephen, good job man ;)
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
  • Who's Online   0 Members, 0 Anonymous, 1008 Guests (See full list)
