u might be able to get louder with less subs and proper air space :01nocomment8so: ...
My combination is set perfect......I have to deal with all 6 - 12" :unknw:
My Subs
TEAM ELEVATION AUDIO
BassRace 140.0-149.9
My Ride
x2
4 of those woofers might get louder than the 6 in the same space. you might have to break down and do a wall or a clamshell. unless your trying to stay out of that class.
That why? I want to stay under my glass and with 4 subs my setup won't work.......a friend of mine did that combination and he hit almost 2 number under mine........I've been with this set up for almost a year now........I just need a box design that will work :search: thank's for the 4-12" set up :hi:
Edited by Trix
My Ride
idk your kinda limited on options.baffel space kinda kills any idea i had on porting up so the enclosure could be 30 deep. maybe do a ass of four inch aero ports facing up like 8 of them but again its in the 1.3 cube per woofer range and it would be tuned higher than you want to go
American Bass*DC Power
What should be the perfect ported box size for the 6 - 12" ? :unknw: because under the subs is the third sit row of the car......I could eliminate that sit row and i think there's 8" more of space :drinks:
My Ride
there is no perfect size but id go 1.5-2 cubes net per, but for a low tuned box of that caliber requires alot of extra airspace due to displacement. plus trying to be big and have that port facing to the rear is seeming a difficult task.but if you go say 25 deep that does not leave much room on the baflle depth wise, the woofers would just fit touched end to end.id pull for that extra space and take some more measurment once you pull the seat out
Could you draw me a design box with the port facing to the rear? because if i take out the third seat, i could push foward the box, let's say 5" from the back door and my batteries could fit below the box......so the box could be around 40" x 32" x 20" :clapping: let's hope i won't pass the rear window........Thanks bro :hi:
My Ride
wow talk about shoving 10gal of shiz in a 5gal bucket! nice setup as is! good luck on better #s
2007 Acura TSX
Stock Navigation
Rockford 360.2 (FOR SALE)
Sundown SAZ3500
2 12" DC Sound Lab LvL4 @2ohm
JL 600/4
2 Sets of Focal 165K2P
Thanks.......I figure out one ported box will give better numbers :friends:
My Ride
Off topic but Trix, I actually watched your whole avatar video, It just kept me intrested.
¿ǝɯɐƃ ǝɥʇ
  • Who's Online   0 Members, 0 Anonymous, 1035 Guests (See full list)
