What Kind Of Box For These?
Well, I went to the carstereo.com box building thing and this is the result I came up with using a 3^3 spec enclosure with a 3"x12" square port along with the info I posted in the first post.
OR
Should I use this program thing instead?
http://www.carstereo.com/help/calc_box.cfm#box
No problem man thats what were here for. But in the Re Enclosure Calculator Put theses numbers in the red spots.
Width: 36
Height: 14
Top Depth: 17
Bottom Depth: 17
Port Width: 3
Port Length 2: 6
Just an example. This would be 3.3 cubic feet tuned to 32Hz
Edit: Sorry I type slow I didn't see that you posted. But carstereo.com Looks good.
Edited by brsteinbach
2 Infinity Reference 1252w 12s
4.2 cubic foot box tuned to 28hz
Sub amp: 1 Profile AP1200
Speaker amp: 1 Sony Xplod XM-504z
Kenwood eXcelon KDC-X492
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
f05112e8-c6ca-4f78-9a8d-47be99303c8b_zps
Diamonds are forever, but 9's end that shit fast....
Width: 36
Height: 14
Top Depth: 17
Bottom Depth: 17
Port Width: 3
Port Length 2: 6
What do you think? I like how RE's tell's you what you need and the dimensions to cut them MDF
Edited by k3n12ock
looks fine, And yea I like that it tells you what to cut.
Now its all up to what you have for a trunk opening.
I have a 97 grand am with a small trunk opening and Im able to get 36" width by 14" height so I figured it would work for you.
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
36" by 14" is like, perfect fitment but then it might fit a little bit too tight (that's what she said) so I tried adjusting it to 33" x 15" x 18" and it roughly add's up to 3.4ft^ tuned to 32hz
That should be a good box. What ever fits in your trunk. I just wouldn't go under 3 cubes.
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
Why not go under 3 cubes? Anyway, I think this will be my weekend project since it's a 3 day.
:D brsteinbach you the man.
Thanks man.
If you were to go under 3 cubes the subs may sound bad but will for surely not play low. My last box was for my 2 12's (check my sig) was 2.4 cubes tuned to 30Hz and it sound like it was tuned to 45Hz (It only hit the high notes). It just sounded awful.
So I try to go 3 cubes or larger. Because the bigger the box the lower your subs will preform.
That is my experience with systems.
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
  • Who's Online   1 Member, 0 Anonymous, 1020 Guests (See full list)
