My Integra Build 2x 15" Dc Lvl4xls 3k Rms *done*
where the ports are gonna be are gonna be alittle below the middle of my hatch window.. 9 cubes for 2 15s is a decent sized box tho, my old one was 8 after all the displacement
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
id look to be in the range of 5 four inch ports at about 22.25 inches long for 30hz but thats still on 62 sq inches of ports
American Bass*DC Power
if im facing it up, i can only go down about 10" because the inside is from top to bottom is 11.5, ive had my ports facing back and i lost alot of output. and i dont ike all the rattling
Team DC Audio
with port up using pvc you will not get the length you need for that 30hz. its not to late to go slot with it. the oly other way i see it working is using elbows on the pipe, idk how much it would effect things tho. hell people use a 90 degree angle with a slot but its a much larger surface .
thats why im doing multiple pvcs, im doing 3 pvcs at 6.15" with the radius of 1.53125.. its 3" pvcs
Team DC Audio
eeehhh, its even less port, you would make tuning but it would be not enough port area. if you went port forward you could do a interchangable slot port plate to change from daily to comp.it would not requre much modification to the enclosure as it stands now.you just need some t nuts and weather stripping
im getting 135 sq inches of port on my tuning at 30hz... which is what rusty told me to go for with my box size... im just double checkin to make sure it was right or not
Team DC Audio
ok guys, with the box's dimensions like this
so 46.25h 31.5w 13d that comes to 9 cubes right.. ok now for the ports...
working with PVC ports
3 ports with a radius of 1.53125 at 6.15" will give me 135 sq inches of port with a tuning freq of 30...4 ports with a radius of 1.53125 at 4" will give me 117 sq inches of port with a tuning freq of 41..
any one able to check the math on that for me?
im just double checking everything that my dad has done, because i know hes super smart but its always nice to check
21 sq in of port
