brsteinbach Posted May 25, 2009 Report Posted May 25, 2009 (edited) this might be stupid but what one do i need What tone? If so then DL the 50hz tone at 0db Edit: DHFHades beat me too it. Edited May 25, 2009 by brsteinbach Quote 2 Infinity Reference 1252w 12s 4.2 cubic foot box tuned to 28hz Sub amp: 1 Profile AP1200 Speaker amp: 1 Sony Xplod XM-504z Kenwood eXcelon KDC-X492 4 and 8 Gauge Knu Big III In 1/0 All in my 90 Accord Diamonds are forever, but 9's end that shit fast....
t-roy Posted May 25, 2009 Author Report Posted May 25, 2009 what should i have the amp settings on, 0? or ? like the subsonic etc... Quote
pear_b Posted May 25, 2009 Report Posted May 25, 2009 DJ @ Audioque can walk you through setting your amp. Quote Team PSI Team Shock Industries Team XS Power Vertex Audio Sundown Audio Knukonceptz
Rogers Posted May 26, 2009 Report Posted May 26, 2009 most if not all bass knobs are for bass boost... which is basically distortion, and it just raises your output voltage... so if you use the bass boost make sure you use a dmm like the guys suggested!.... if you use the boost your gain knob will have to be lower than normal... Quote http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
Boon Posted May 26, 2009 Report Posted May 26, 2009 most if not all bass knobs are for bass boost... which is basically distortion, and it just raises your output voltage... so if you use the bass boost make sure you use a dmm like the guys suggested!.... if you use the boost your gain knob will have to be lower than normal... On most high-power monoblocks they're actually remote gain cuts. You set the gain at the amp with the remote unplugged and then you know that even with the knob full-tilt you'll never exceed it. Quote 10.x volts fo' life!
Rogers Posted May 26, 2009 Report Posted May 26, 2009 On most high-power monoblocks they're actually remote gain cuts. You set the gain at the amp with the remote unplugged and then you know that even with the knob full-tilt you'll never exceed it. ok... ive only had one bass knob and it was on a bxi608 and it was bass boost.... to set it i turned everything on the amp down and turned the knob all the way up and then started setting the gains on the amp with a dmm.... that way when the knob was all the way down there was no bass.... Quote http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
t-roy Posted May 27, 2009 Author Report Posted May 27, 2009 http://www.realmofexcursion.com/downloads.htm this will not work for me here at home i tried it at work and it worked fine, but know i'm back home and i get the site i click the 50hz and nothing happens any ideas? Quote
t-roy Posted May 27, 2009 Author Report Posted May 27, 2009 yes you set the remote gain by adjusting the amps gain to around 3/4 and the boost way down because boost is really just a cause to have your gain lower and cause you to clip at a lower gain, Quote
