Jl Amp
is this amp dead its a jl 1000/1 and I checked my amp wire they are fine, the problem is when the amp turns on the low ohm and low voltage lights come on and the voltage at the amp drops to like 7 but when it's not on my voltage is at 14.4v any body?
Jensen 9511TS~For Sale
JL Audio 300/4~For Sale
JL Audio1000/1~For Sale
Mephis 6.5 componet sets front and rear
4 15" Fi Q's in a 16 cuft box tuned to 29hrz
Hmmmm... Check the settings and make sure you aren't defeating another filter, and also try swapping out the inline fuse (if you have one)
Car
1996 Sable LS
8,000K Bi-Xenon HID's
Pioneer Premier DEX-P1R
Diamond Audio D351, Diamond Audio D362i, Diamond D3TAK off Kicker ZX200.4
Custom 15" 13w7 motor, 3.5" aluminum coils dual 1 ohm off NV-AM25001
Dynamat Dynaliner Second Skin Damplifier Pro
Stock 130A Alternator
My Build
Truck
1995 Ford F-150 Flareside XLT
10,000K Bi-Xenon HID's, 15,000K Bi-Xenon HID's
Kicker KS6502, KS400 off Pioneer Premier PRS-D4100F
Truck Build
Ref(s) Rogers, Jared, Mikesmith0890, Twigz, DHFHades, BASS14, Solo_X18, mrafrica, camino_1to3, kickerassman
[speakerman9000] 5:43 pm: if sony sucks so bad how come my amps still work when i had 3 12s on it
[capalass23] 11:27 pm: wow u grand man poopin out babys like hto cakes
[KevinniveK] can u have sex later please hes helping me
I have a 250 amp breaker, voltage to amp doesn't drop till it turns on
I would take the amp out of the car , hook it up straight to a 12v source and see what it does with nothing else hooked up to it other than power , ground and remote . If it does the same thing .. its time to take the amp apart and inspect it for any visual damage... then time to send it to DB-r !
Too Much Stuff to list .
Set the Infrasonic filter to off, Bass EQ off, the LP filter to off, Input Voltage to low, Q to about 1.5, and then check to see if your wires are seated correctly in the amp and in your circuit breaker
Car
1996 Sable LS
My Build
Truck
Truck Build
yeah man you should this.
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
While its still hooked up, try what I said, then if it still does it, follow what Neel said to do
Car
1996 Sable LS
My Build
Truck
Truck Build
