45's In A Box
is it gonna help any to put 45's in a box tuned to 32hz i just need to pick up a couple 10th to brake a 150.xx also my box in 9.99 cubes gross and around 8 cubes net after all dissplacments port is 100sqin 4"x25" and 21.5"deep if i was to take 2" of my port what will my tuning be say it was 19.5" please help
It depends on the bracing you currently have id say. Id does help with airflow alot tho. Think of a car exhaust, if its got smooth bends the air flows better than the crinkle bent crap from Midas, same inside your box, Squared edges hinder smooth flow.
You could pick up a tenth or 2 id guess if your box flexs alot, if the box is flexing, the pressure inside isnt exiting as forcefully as it could.
93 Chevy Silverado
Crossfire,Dayton
Soon to have 6 Lvl4 15s
DC Audio Dealer and Team Member
How many of what size subs?
The angles may hurt in some setups, or do nothing.
What can help depending on your cone area is reducing box volume and shortening the port.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
i would like to think i have 0 flex the box is braced good and is 1 1/2 all around but can you tell me if making the port a littel shorter will help to get me around 35hx thanks for your reply
I can let you in on a little secret of mine.
Use clay, put it in the corners of the box building them out at a certain angle,
add just a little at first, then test.
Then add some more and test again,
then add more and test again.
and so on until you have good data to go on.
Then change the angle and repeat.
If something works, leave the clay in and fiberglass over it.
If it hurts you, simply remove the clay.
Ed Lester
ShowtimeSPL Host
My old Build Log
ok sounds good but i have very littel time on the tl with the specs on the box and my eqiment i listed what whould you do
PM replied, do that, lol
Ed Lester
ShowtimeSPL Host
My old Build Log
  • Who's Online   1 Member, 0 Anonymous, 1975 Guests (See full list)
