ok my head unit has 1 preamp out and i want to run 2 amps 1 amp for my mids and highs and the other amp for my sub. how would i go about running these? my headunit is a jvc kw-avx710 if that helps any.
assuming your amps have HPF and LPF you can split the signal with y-adapters. run one to the highs amps and set that amp to HPF and the other to the sub amps and set that one to LPF. what amps are they?
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
i would suggest getting an electronic crossover that has ouputs for highs and lows or you can do it the cheap brokeass way and just get y splitters, and remember every time you split your signal you loose signal voltage...
here is an example... its a 3-way but you can also find 2-way crossovers.... something like this is your best bet to a clean system....
http://cgi.ebay.com/KICKER-3-WAY-ACTIVE-EL...%3A1%7C294%3A50
Edited by Rogers
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
i havent got them yet. i am looking at either hifonics, kicker or rockford.
when i get my check ill talk to u enemy. im still interested in the amp and now the cross over. i get my check the first.
here are the amps im thinking about running
sub amp
http://www.sonicelectronix.com/item_2809_R...r+T10001bd.html
mids and highs amp
http://www.sonicelectronix.com/item_9893_R...nch+P400-4.html
mids and highs im lookin at
http://www.sonicelectronix.com/item_2205_R...unch+P162S.html
Edited by monoxide
i have a crossover for sale that will solve your problem. B)
ive heard ALOT of bad things about soundstorm, but crossovers are pretty simple so that should work...
3 Kinetik Hc2000's
Dual 200amp alts.
honestly i like this idea best
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
as long as it works till i cna get some money to buy a better one.
so now i have to have fun and run all new speaker wires now. i hate running wires in my truck. lol
07 so you would recommend the y adapters?
Edited by monoxide
  • Who's Online   0 Members, 0 Anonymous, 752 Guests (See full list)
