sound deadener and space.
Edited by velcroslap
* Head Unit: Kenwood KDC-MP732
* iPod Interface: KCA-iP500
* Front Stage: Rockford Fosgate Power T1652-S
* Front Stage Amp: Rockford Fosgate Punch P400-2
* Rear Stage: Alpine SPR-13C Type-R 5-1/4"
* Amp: Rockford T10001bd
* Subs: (2) 15" Rockford P3s
* Front Battery: Optima RedTop
* Back Battery: Kinetic Hc2400
* Wiring: Rockford 1/0
* Big 3: Rockford 1/0
* Enclosure: Idyllic
Low voltage + clipping = BTL death.
You would want an amp that will do around 2500 rms daily. You can throw more at it, but in your case, you should just keep it on the lower end. I would say a nice battery up front and at least 1 group 31 battery in the rear with around 2+ runs of 1/0, big 3 in 1/0, Alt power of at least 150A and a nice signal processor.
Running a BTL or any higher powered subwoofer is not easy if you dont know what you are doing, and not cheap either.
a 2000wrms amp, 1/0 gauge wiring, batt or two in the back, possible HO alternator. oh and at least a 5cuft box
What are legitimate amps to use that puts out that much wattage?
yah just get a bl, they bang with the right enclosure.
sorry sir but u do not have the right enclusure.
but for the OP i would say 15 BLs would be really nice, but if u want to go with 18s i say do a blow through.
1996 deville on 18" full face rims
-2 gauge wire.
-a2400db
-RE SE-X in a 4ftc box tuned to 32hz
-tview touch double din
-rockford punch 6x9s(rear)
-mtx 6.5(front)
front and rear stage will soon be changed build log will start as soon as it aint cold!
What you mean a blow through?
the sub box goes into your bed with a teanou(sp?) cover and you cut a hole from the bed to the cabin behind the seats.. easier said then done.. but when done right it sounds nice and looks good
stealth edit: but with a truck like that im sure you would cry cutting it up ahaha. not something to do if u dont know wat your doin. if u have any reputable shops around u have them take a look.
Edited by tudski
-2 gauge wire.
-a2400db
-mtx 6.5(front)
  • Who's Online   0 Members, 0 Anonymous, 628 Guests (See full list)
