00_XJ Posted June 4, 2009 Report Posted June 4, 2009 is there supposed to be a fuse block on the wire going from to positive to the alt? and could i just disconect the original wire from the pos to the alt? Yes and its recommended that you keep the original wire also. Quote 2000 Jeep Cherokee -DC Audio -Memphis -Audioque -SecondSkin -Pioneer -KnuKonceptz
mr.wattz(405) Posted June 4, 2009 Report Posted June 4, 2009 Yes and its recommended that you keep the original wire also. so if i did 1/0 gauge wiring what size amp of fuse should i use Quote
00_XJ Posted June 4, 2009 Report Posted June 4, 2009 (edited) so if i did 1/0 gauge wiring what size amp of fuse should i use I think I read that wrong, are you talking about to your amp or for the Big 3? If for your amp look for the amount of amps your amp pulls. For your alternator, well how many amps your alt produces. Edited June 4, 2009 by JGod Quote 2000 Jeep Cherokee -DC Audio -Memphis -Audioque -SecondSkin -Pioneer -KnuKonceptz
mr.wattz(405) Posted June 4, 2009 Report Posted June 4, 2009 What amp are you running? my alt? not sure whatever has been on it but i want to change it any suggestions? i have a 03 jeep grand cherokee with two 12's and 1 1800 watt amp and a 2 fared cap right now im about to be 4 12's and two 1800 watt amps but not sure when should i upgrade my alternator now just to be safe? Quote
00_XJ Posted June 4, 2009 Report Posted June 4, 2009 my alt? not sure whatever has been on it but i want to change it any suggestions? i have a 03 jeep grand cherokee with two 12's and 1 1800 watt amp and a 2 fared cap right now im about to be 4 12's and two 1800 watt amps but not sure when should i upgrade my alternator now just to be safe? I would, contact mechman on here. He should be able to hook you up. Quote 2000 Jeep Cherokee -DC Audio -Memphis -Audioque -SecondSkin -Pioneer -KnuKonceptz
mxer111 Posted June 4, 2009 Report Posted June 4, 2009 Way to thread jack lol Quote Looking for a CRX to get back in the game. And a gas tank for my 01 r6. Hit the PM
EricM9104 Posted June 4, 2009 Report Posted June 4, 2009 so if i did 1/0 gauge wiring what size amp of fuse should i use 200-300a depending on the quality of the wire. Quote 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
BHSskaterBHS Posted June 4, 2009 Author Report Posted June 4, 2009 i shortened the wire added a fuse block and relocated my ground wire which is also shorter now. Quote 2002 FORD EXPLORER PACKED WITH SOME CHEAP SUBWOOFERS!
