Basshead08 Posted June 4, 2009 Report Share Posted June 4, 2009 If it was me I would do a least 2. Quote System tear out has begun...Out with the old i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell Look at the underlined text hahahahahahahaha I think of it as the virgin losing the virginity technique not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme Link to comment Share on other sites More sharing options...
Soulman07 Posted June 4, 2009 Report Share Posted June 4, 2009 It'll help that's for sure, Under most circumstances at idle you won't be able to tell the difference. Once you put a load on the single +/- run you'll actually see where the drop comes into play by all the current running through the single run of wire. So with having multiple runs of wire to the rear the load is split evenly amongst them all. Which should actually help with voltage dropping quite a bit. A few sites claim that it can help as much as 1.1-1.5 volts on longer runs of wire. I myself run around 22 feet from the front to the rear, so there's nooooo question as to whether or not multiple runs are needed. Distance plays a huge factor in there was well Quote 1993 Chevrolet SWB Pickup Viper 791XV Primer Stage 5/8 Static Drop Kinetik HC1800 Big 3 Knu Flex 0 Team Tex Flex Link to comment Share on other sites More sharing options...
J00bles Posted June 4, 2009 Report Share Posted June 4, 2009 do a run for every 2-3 thousands watts of power that your amp will push. 2 runs would work fine, especially if they're a nicer, larger brand (like knu flecks, or some of the rockford/stinger stuff) good luck Quote 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel Link to comment Share on other sites More sharing options...
Joeskey Posted June 4, 2009 Report Share Posted June 4, 2009 I would run a couple to the trunk, i mean it wouldnt hurt u kno Quote "never drive faster then your guardian angel flies... good think my guardian angel drives a twin turbo ed beast" "its time has come for those who are different to stand united" Link to comment Share on other sites More sharing options...
