Fs: Rf T800.4, Stinger SPV35, RF Rca's, Rearview TV & Much More
Updated list as of 2-23-10 11AM CST:
6 - Rockford Fosgate T1 12's (D2) - $150 each
7 - Rockford Fosgate 16 Ft Premium Dual Twist RCA Cables (Directional) - $15 each
2 - ProAcoustic 1.2 farad Stiffening capacitors - $20 each
6 - BNIB Blue 80 MM LED cooling fans (these are computer cooling fans but will work on 12 volts) - $10 each
1 - Stinger SPV35 - $75
Jared Nixon  A.K.A. Jsmoke
My Car Stereo Website: 3rd Coast Customs
My Fishing Website: BigLake411.com
Add me as a friend: Myspace
Download: Check out my Audio Calculations Spreadsheet (Microsoft Excel)
ATTENTION ALL SMD MEMBERS: Do not under any circumstance buy anything from Chassistech! They do not stand behind their products & their customer service is horrible. They do not actually manufacture lowering springs, they drop ship them from Spring Tech. Chasistech.com also does business as Airbagit.com, Streetridepro.com & Truckinsuspension.com. They are all the same company! Do not trust these bastards! Their products are cheap & more often than not, you don't get what you actually order in the first place! YOU HAVE BEEN WARNED!
Updated list as of 2-23-10 11:45AM CST:
4 - Rockford Fosgate 16 Ft Premium Dual Twist RCA Cables (Directional) - $15 each
Specifications
•Internal resistance <6 mOhms
•5 Second Cranking 525A
•Weight 27.6 pounds
•Temperature range -15 C to + 0 C
•Constant Discharge Capacity at 77 degrees to 10.50 Volts
•20 Hour Rate 1.75A / 35.0ah
•5 Hour Rate 5.95A / 29.75ah
•1/2 Hour Rate 43.75A / 21.90ah
•Typical Cycle Life
•350 cycles at 100% depth of discharge (down to 10.5 volts)
•The shallower the discharge the longer the life
•Never discharge battery below 10.5 volts or let battery sit in a discharged state
•Maximum Charging Current 13.2 Amps
•Maximum Charging Voltage 15 Volts (Cyclic Use)
•13.8 Volts (Standby Use)
Dimensions
8-1/4 inches height x 7-3/4 inches wide x 5 inches deep
sounds good. Just let me know. This stuff is priced to move!
Updated list as of 2-24-10 11:15PM CST:
The 2-T3K's are oficially SOLD They shipped out today.
I'm glad you got your stuff. Let me know if you need anything else. Thanks for the positive feedback.
