shainemcconnell Posted June 8, 2009 Report Posted June 8, 2009 I am in the process of redoing my system right now... Nothing is hooked up at the moment, I noticed that my Alt. gets pretty warm quick...is this a normal thing, my battery gauge still says between 14 and 15.2 volts. never really felt the alt after a few minutes of running from a cold start. 2010 IDBL Rookie 1 North American Champion 2009 IDBL Rookie 1 Fl State Champion 2009 EBB Fly Weight 3rd Place Fl State Finals 2006 Silver Grand Prix GXP :Diablo Audio Hellfire 1000.1, JL Audio 300/4, One 13W7, ZR650, VR690, JL Cleansweep setup. Team Pure Pressure
Andrew2944r Posted June 8, 2009 Report Posted June 8, 2009 Yeah. Alts do get pretty warm. Team Ampere Audio
Shyne151 Posted June 8, 2009 Report Posted June 8, 2009 It's a metal housing in an engine bay... it's going to get hot. -Installer for Duke's Car Stereo 2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune. RF T1000-1bdCP and T400-4 Boston Acoustics SPG 555 Kenwood eXcelon 995 RF Punch 6.5" components and MB Quart Premium 6x9"s Powermaster Alternator, YellowTop D34, Vmax CT1000
shainemcconnell Posted June 8, 2009 Author Report Posted June 8, 2009 It's a metal housing in an engine bay... it's going to get hot. it got warm a a few minutes after i started the car with the hood up...rest of engine was not yet. my engine gets as hot as a hot day in hades. 2010 IDBL Rookie 1 North American Champion 2009 IDBL Rookie 1 Fl State Champion 2009 EBB Fly Weight 3rd Place Fl State Finals 2006 Silver Grand Prix GXP :Diablo Audio Hellfire 1000.1, JL Audio 300/4, One 13W7, ZR650, VR690, JL Cleansweep setup. Team Pure Pressure
joakwin Posted June 9, 2009 Report Posted June 9, 2009 the alt spins at a different speed then the engine rpm 84 austin mini building a system for it currently
Soulman07 Posted June 9, 2009 Report Posted June 9, 2009 Yeah they get pretty warm... if you are internally regulated then you can feel the voltage drop pretty good. I had the MLA set at 15.3, once the aluminum heats up and starts kicking heat around... After driving for around 15-20 minutes in the summer I'd drop to 14.4. Long driving trips = high 13's to 14.1. I got an external regulator and now the voltage doesn't fluctuate at all from 15.3. Soooo I mounted it inside the glove box and problem solved there. Don't really worry about the operating temperature of the alternator too much. I'd be more concerned about heat causing you to lose voltage. 1993 Chevrolet SWB Pickup Viper 791XV Primer Stage 5/8 Static Drop Kinetik HC1800 Big 3 Knu Flex 0 Team Tex Flex
shainemcconnell Posted June 10, 2009 Author Report Posted June 10, 2009 Yeah they get pretty warm... if you are internally regulated then you can feel the voltage drop pretty good. I had the MLA set at 15.3, once the aluminum heats up and starts kicking heat around... After driving for around 15-20 minutes in the summer I'd drop to 14.4. Long driving trips = high 13's to 14.1. I got an external regulator and now the voltage doesn't fluctuate at all from 15.3. Soooo I mounted it inside the glove box and problem solved there. Don't really worry about the operating temperature of the alternator too much. I'd be more concerned about heat causing you to lose voltage. awesome thanks....right now my car is usually running between 14.8 and 15.3 V...granted I have no system in right now....AHHHH...well the silent ringing in my ears has about all but stopped now...HA HA HA...nah its not that bad... 2010 IDBL Rookie 1 North American Champion 2009 IDBL Rookie 1 Fl State Champion 2009 EBB Fly Weight 3rd Place Fl State Finals 2006 Silver Grand Prix GXP :Diablo Audio Hellfire 1000.1, JL Audio 300/4, One 13W7, ZR650, VR690, JL Cleansweep setup. Team Pure Pressure
