Amp Fuxord?
_AnGeL_
ok the other day my amp was acting weird, my speakers would make a really high pitched hiss and the amp would go into protect and then it would hiss every 10-15 secs.... so i thought it might've been a wire grounding out or a pinched rca. i take off my door panels check all the wires and check my rca wire and everything is fine. i disconect to RCA wire from the HU and leave it connected to the amp, when ever i touch one of the rca i get a real bad noise put nothing happens when i touch the other side.... i think my amp took a shit but im not sure, anyone ever had this happen to them before???
the amps a kicker kx150.2
Head Unit: Pioneer Premier Deh-600ub
Front Stage: (2) Whip Audio 8" Mid-Bass (2) Whip Auido 6" Mid & (2) Audiopipe ATX-3720
Amps: (2) Cadence TXA300-4 :D
Amp Kit: Knukonceptz
Coming Soon: already ordered
Sub: 2 DD T1508's
Amp: Sundown saz-1500
Tired of the lag? Come get crunk!
bump, anyone got any input????
Sub: 2 DD T1508's
Put a DMM on the amp and make sure its reading solid voltage.
last time i had those symptoms my rear bat was disconnected from the charging wire and the amp was running on very low voltage
-Drew
uhoh_45 said:
-Drew
i dont have a dmm, or a rear batt and im sure the power wire is good, could it be a bad ground???
and is it normal for the rca to do that??? when i touch one of the two prongs that insert into the rca outs of the radio i get a real bad static type noise. i was thinking maybe the rca inputs on my amp are fuxord????
Sub: 2 DD T1508's
bump, i did some more testing on the amp yesterday, its only one channel doing the noise, the other channel works fine. so im guessing one of the channels is fuxord? or could it be the rca input on the amp?
Sub: 2 DD T1508's
Try swapping the RCA sides ie. put the left in the right, and the right in the left.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
  • Who's Online   0 Members, 0 Anonymous, 688 Guests (See full list)
