LordArcane Posted June 9, 2009 Report Posted June 9, 2009 you'll prolly want to do the big 3 upgrade also to take advantage of the bigger amp alt Quote
Jared420 Posted June 9, 2009 Author Report Posted June 9, 2009 depends on the company you buy the alternator from, iraggi, dc alts, theres a bunch out there that people run on the forum. but its all gonna cost around $300 or so. 300 for just the alternator or alt and battery? also how hard is it to put in one of those alternators, would i need it professionally done? Quote 2012 silverado ext cab ltz 24" kmc rims AudioQue 2200 Pioneer AppRadio Alpine mrx f35 4 channel Bose mids and highs Iraggi Alt + stock alt in a DC power dual alternator kit Yellowtop+stock under hood 0 gauge Knu wire Big 3 4 gauge stinger (4 chan wiring) 3 DC 10'' LVL3 with LVL4 parts
alvitae Posted June 9, 2009 Report Posted June 9, 2009 Not a fan of capacitors myself. Even of they do help there are better and cheaper ways to go. The cheapest electrical upgrade you can do is the big 3. It's usually where you start. The one here is my favorite big 3 tutorial. Big 3 tutorial Quote
LordArcane Posted June 9, 2009 Report Posted June 9, 2009 300 for just the alternator or alt and battery? also how hard is it to put in one of those alternators, would i need it professionally done? most alts are 2 bolts main to take it off bolt for power wire and a plug on the back its pretty easy to do if but if you don't feel you can do it yourself prolly best to have someone to do it for you friend that works on cars alot or pro as for price not sure myself i still run stock alt Quote
Jared420 Posted June 9, 2009 Author Report Posted June 9, 2009 you'll prolly want to do the big 3 upgrade also to take advantage of the bigger amp alt Again sorry but im basically electrically retarded whats the big 3? Quote 2012 silverado ext cab ltz 24" kmc rims AudioQue 2200 Pioneer AppRadio Alpine mrx f35 4 channel Bose mids and highs Iraggi Alt + stock alt in a DC power dual alternator kit Yellowtop+stock under hood 0 gauge Knu wire Big 3 4 gauge stinger (4 chan wiring) 3 DC 10'' LVL3 with LVL4 parts
LordArcane Posted June 9, 2009 Report Posted June 9, 2009 Not a fan of capacitors myself. Even of they do help there are better and cheaper ways to go.The cheapest electrical upgrade you can do is the big 3. It's usually where you start. The one here is my favorite big 3 tutorial. Big 3 tutorial he said it best what the big 3 is go to that link and it will walk you thru it step by step Quote
Jared420 Posted June 9, 2009 Author Report Posted June 9, 2009 he said it best what the big 3 is go to that link and it will walk you thru it step by step So basically just thicker wire from the alt to battery? and this will help with voltage drop and put out more power? Quote 2012 silverado ext cab ltz 24" kmc rims AudioQue 2200 Pioneer AppRadio Alpine mrx f35 4 channel Bose mids and highs Iraggi Alt + stock alt in a DC power dual alternator kit Yellowtop+stock under hood 0 gauge Knu wire Big 3 4 gauge stinger (4 chan wiring) 3 DC 10'' LVL3 with LVL4 parts
justin smith Posted June 9, 2009 Report Posted June 9, 2009 1st.) xs power battery under the hood 2nd.) big three 3rd.) h.o. alt.... then youre set Quote justin smith 1996 mercury grand marquis 20'' bentchi b7 lexani n3000 245/35/20 cactus 5kw at 1ohm dcr(beast) 2 18'' btl's in a 14.15^ft wall tuned to 35hz with 210'' of port kicker zx650.4 componets in still the works 200amp motorcraft alt xs power d3100 (beast) kenwood ddx512 h.u. you mean my EX? the one I dumped? just remember every time you kiss her that i used to cum in her mouth and BTW your girl just called me.... pure pwnage
alvitae Posted June 9, 2009 Report Posted June 9, 2009 So basically just thicker wire from the alt to battery? and this will help with voltage drop and put out more power? That and upgrading grounds. People that are new to audio frequently underestimate the grounds. It is just as if not more important than power I've found. I've got my biggest gains, And also biggest headaches from the grounds. Quote
Guest Posted June 9, 2009 Report Posted June 9, 2009 So basically just thicker wire from the alt to battery? and this will help with voltage drop and put out more power? - Positive from battery to positive from alternator - Negative from battery to ground - Engine block to ground not put out more power per se, but making your electrical system more efficient...which in turn would put out more power yea lol Quote
