DNASTY01 Posted June 9, 2009 Report Posted June 9, 2009 I have a db eletric 200 amp alternator and a kinetik 2000 and 800 for my batteries. When I have my bass knob about 3/4 of the way turned up my volts drop down below 12.1 and it cuts off when really low bass comes on. I'm trying to see what i could do to eleminate the problem. Should I upgrade to a dual alternator setup or maybe put a line drive in it or even add another kinetik 2000. How many of you guys that have big systems are running dual alternator setups and if not what are you running to keep ya'll systems going. If I have the bass knob turned down all the way and my bass level on my cd player at -6. It plays fine at about 13.7 volts driving down the road. I want to have the volts running at 14.4 or at least 14.0. Any ideas.. Thanks Dennis YEAAAAA!!!!!!!!! Let's get em 4 JL Audio 12w6's (wall) 4 Pioneer 6x9's (built into the wall) 4 Memphis 6.5's components (one set in kick panel and one set in the door) Orion 2400 amp (old long black amp) Orion 800.4 amp Mechman 250 amp rhino series alternator 0 guage everywhere Kinetik 2000 for bass Kinetik 800 for highs Memphis Digital Processor 147.1 db @60 hertz
lanman31337 Posted June 9, 2009 Report Posted June 9, 2009 Is your bass knob a bass knob or does it adjust your gain? What frequency does it boost? Are you clipping and pulling excess current at that frequency? 2 - Audiopipe AP30001Ds 1 - Lanzar Opti Scion 600.4 4 - Lanzar Optidrive 1232D's 1 - Lanzar Opti 5.1 1 - Lanzar Opti 6.1 1 - Lanzar Opti 6C midbass 1 - Alphasonic PCT6551 1 - Lanzar VX830 1 - JBL 22 band EQ 1 - Lanzar SDBT75NU 1 - AudioControl Epic160
sully Posted June 9, 2009 Report Posted June 9, 2009 Get your alt dyno'd to see if it is really doing what it says and check the idle output. If it is like alot of other cheap HO alts it has little to no output at idle and is killing your voltage. Get a Mechman, Iraggi or Ohio Gen alt and i would put money on the problem being fixed or at least much better. Also would recommend upping your voltage either by a MLA module or research your specific alt to see what kind of diodes you can put in line to trick it into charging at a higher voltage. this is a quote from an old Mechman post that may help you: If you have an AD or CS series GM alt, go buy yourself a $.75 1 amp diode and solder it in-line in the sense wire on the alternator plug. It will boost the charging voltage accross the board .6 -.7 Volts. Want higher voltage? just double them up for another .6 - .7 volt increase If you have a stock 3G or 4G Ford, go buy your self a 6 amp diode for $1.50 at radio shack and solder it in-line in the yellow sense/power wire on the alt plug for a .6 - .7V increase. (high output versions using an aftermarket rotor will require (2) 6 amp diodes) hope this helps 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
DNASTY01 Posted June 9, 2009 Author Report Posted June 9, 2009 Get your alt dyno'd to see if it is really doing what it says and check the idle output. If it is like alot of other cheap HO alts it has little to no output at idle and is killing your voltage. Get a Mechman, Iraggi or Ohio Gen alt and i would put money on the problem being fixed or at least much better. Also would recommend upping your voltage either by a MLA module or research your specific alt to see what kind of diodes you can put in line to trick it into charging at a higher voltage. this is a quote from an old Mechman post that may help you: If you have an AD or CS series GM alt, go buy yourself a $.75 1 amp diode and solder it in-line in the sense wire on the alternator plug. It will boost the charging voltage accross the board .6 -.7 Volts. Want higher voltage? just double them up for another .6 - .7 volt increase If you have a stock 3G or 4G Ford, go buy your self a 6 amp diode for $1.50 at radio shack and solder it in-line in the yellow sense/power wire on the alt plug for a .6 - .7V increase. (high output versions using an aftermarket rotor will require (2) 6 amp diodes) hope this helps This helps out alot Sully. Thanks. I have a alternator from db eletric and i thought they were decent alternators. I may look into getting another one. YEAAAAA!!!!!!!!! Let's get em 4 JL Audio 12w6's (wall) 4 Pioneer 6x9's (built into the wall) 4 Memphis 6.5's components (one set in kick panel and one set in the door) Orion 2400 amp (old long black amp) Orion 800.4 amp Mechman 250 amp rhino series alternator 0 guage everywhere Kinetik 2000 for bass Kinetik 800 for highs Memphis Digital Processor 147.1 db @60 hertz
