ok so im trying to learn how to build boxes on ketchup and its not really lookin that great.... i built an enclosure and it looks fine but definately not like the ones ive seen on here... the walls are paper thin and i cant get the measurements exact.... they are always a fraction off....
i started by making a rectangle and used the pushpull to make it the correct height..... am i doing this wrong.... can anybody tell me how to do this? or is there a tutorial for making subwoofer enclosures on sketchup?
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
i always just type in what i want it say push/pull click on push or pull it just little bit and just type like 3/4 or .75 and hit enter and it goes to that size same with lines and stuff just type in the lenght and hit enter on for things that have 2 sides like square or what ever it would be 30, 30 then enter. i just played around with it befor i start to build anything with it myself cuz i didn't see much help learning it
ok cool... i see how to do that now... how do i build the vertical walls? do i build them to the side and then move them? or buld them on the bottom piece? im trying to piddle around with it but im not getting very far...
3 Kinetik Hc2000's
Dual 200amp alts.
what i do for side walls is just build the 2d (paper thin) wall going up the push/pull it to the thickness i want or build the outline on the base of the box to lenght and thickness and pull it up to the height i want this way doesn't work for angled side peice tho, for angle i use the first way and just build the wall up to its height and thickness and pull it to the lenght i need, i'm sure theres a better way of doing it, i know you can build peice and move them into place i think i just never figured out how to do it yet
i'm kinda in same boat as you still learning what all i can do with it and figuring stuff out but i how i can be of atleast a little help :)
ok im figuring it out... but its got me pissed now... ive got the bottom piece and 3 sides but when i do the fourth side it completes the box by putting a top piece on it for me, so i erase the top piece and try to push pull the fourth side and it just sucks that piece into the box 3/4" instead of making the wood thick.... plus when i try to make the top piece it put its on the inside of the walls instead of letting me place it on top of the box... it wont let me make it 30 x 35
3 Kinetik Hc2000's
Dual 200amp alts.
http://www.stevemeadedesigns.com/board/ind...ic=40479&hl
after reading this i could make these. It doesnt cover everything but it will get ya started
it says the address is not valid when i click the link... but that last pic is basically what im trying to do.... btw how do i take a screen shot? i cant get it to quit sucking the boards in when i do the push pull....
3 Kinetik Hc2000's
Dual 200amp alts.
