what ohm load will the sub be run at if you can give me that i'll try and recommend an amp
Most likely dual 2 ohm, or dual 4 ohm if that would be better (both are available with the sub) and i appreciate it
if you do dual 2ohm you could go with the soundstream TRX700D 700 rms @ 1ohm, hifonics BXI 610 600rms @ 1ohm or the Rockford Fosgate T500-1bd 500rms @ 1 ohm but im sure the rock will do more than that probably somewhere in between the other 2 the rockford was the most expensive about 300 online but if it was me its the one i'd get given the sub
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
