With a 1000 watt amp, how much rms or watts would I get with the diamond d6? I beleive they get a nominal rms of 500 watts and max output of 1000 watts.. I don't really know how to calculate and the amp is temporary use. -Thanks
depends on the amp, the wiring, the box
the 12" d6 is rated at 600/1200.... my best friend had 2 of them running off of 2 diamond d3 800.1's daily.... and they seemed to love the power.... i had one running off of a hifonics bxi608 600rms(a tad over rated...) and it just laughed at the power....
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Thanks, thats all i needed to know lol.
ill be getting one in a custom ported enclosure - magnet facing upward.. just hoping they bump the shit out of my amp :D
it would be the other way around... the amp would bump the shit out of them if its got enough balls
3 Kinetik Hc2000's
Dual 200amp alts.
you don't get rms with a sub, it's the amp that puts out the power not the sub. Can't say how much wattage you'd be feeding the sub because we don't know what amp you have, or what impedance the sub is. Give said info and we can help you out.
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
I have a nitro bmw-482, the impedance will be 2 ohms unbridged... i guess you guys can tell i lack the education of this type of stuff lol so i apologize
ok, the specs on the amp are:
100 watts x 2 channels
150 watts x 2 channels
Bridged RMS Power 300 watts
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 Ohms
Your sub is a DVC, but does it have dual 2 ohm coils or dual 4 ohm coils? If dual 2 ohm coils, the final impedance will be either 4ohms or 1ohm, depending how you wire the coils. I think it's clear that you should wire it to end up 4ohms since that's the minimum impedance your amp can handle when bridged. At that point you'd only be able to feed it 300 watts rms (if you could even get that much out of it) which is severely underpowering that sub, which has a 600 watts rms rating. You can run it like that, just don't get too happy w/the volume knob.
If you have a dual 4 ohm sub, your final impedance will be 2ohms cause you won't wire it to be 8ohms, at that point your amp will have issues cause the impedance is too low.
that would be my answer as well
Well I know either way I would be underpowering the sub. no matter what way I wire it up lol. To conclude I will just buy a new amp, I didn't think I would be underpowering it by that much haha
what ohm load will the sub be run at if you can give me that i'll try and recommend an amp
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
  • Who's Online   0 Members, 0 Anonymous, 550 Guests (See full list)
