dtbrown Posted June 16, 2009 Report Share Posted June 16, 2009 Doing a enclosure build and friend wants specific bass tuning. If anyone knows the resonant frequency of a Chevy avalanche that would help a lot with my tuning and box design. thanks, Jeff Link to comment Share on other sites More sharing options...
Boon Posted June 16, 2009 Report Share Posted June 16, 2009 I would sweep it if I were you. One persons peak might not be yours. Even a little bit of Dynamat can totally mess up your resonance for example. 10.x volts fo' life! Link to comment Share on other sites More sharing options...
dtbrown Posted June 16, 2009 Author Report Share Posted June 16, 2009 I would sweep it if I were you. One persons peak might not be yours. Even a little bit of Dynamat can totally mess up your resonance for example. I just need a ball park idea. Even with dynamat it won't change it by that much. And for the most part a same vehicle will be pretty close frequency wise. So if someone gives me a number from 45-50hz then that's tell me it tunes a little high or if they tell me 40-45hz that tells me it tunes a little low. Thanks, Jeff Link to comment Share on other sites More sharing options...
CaptainzPlanetz Posted June 16, 2009 Report Share Posted June 16, 2009 I just need a ball park idea. Even with dynamat it won't change it by that much. And for the most part a same vehicle will be pretty close frequency wise. So if someone gives me a number from 45-50hz then that's tell me it tunes a little high or if they tell me 40-45hz that tells me it tunes a little low. Thanks, Jeff I think there was something about using a 10" woofer in a sealed box, then playing a sweep and whatever frequency was the loudest/made you car shake was your resonant Frequency, I forgot the exact details but maybe someone with more experience with finding Resonant frequency can chirp in. Edit: Here is a thread I found that had some tips for finding the resonant Frequency http://www.stevemeadedesigns.com/board/ind...onant+Frequency ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members. Link to comment Share on other sites More sharing options...
dtbrown Posted June 16, 2009 Author Report Share Posted June 16, 2009 I think there was something about using a 10" woofer in a sealed box, then playing a sweep and whatever frequency was the loudest/made you car shake was your resonant Frequency, I forgot the exact details but maybe someone with more experience with finding Resonant frequency can chirp in.Edit: Here is a thread I found that had some tips for finding the resonant Frequency http://www.stevemeadedesigns.com/board/ind...onant+Frequency Thanks and I understand how to do a resonant frequency test but it's time consuming and if someone can help me on here and give me a rough idea that would help a lot. Link to comment Share on other sites More sharing options...
