siucsaluki11 Posted June 19, 2009 Report Posted June 19, 2009 So if i were to make a box for 2 12s, and i want the port between them but the port is gunna be like 30" long and 4" wide. Its obviously going to have to split when i get close enough to the back wall. How do i calculate the length for this? box will be 4 cubes at 35 hz woman..cant live with em...cant shoot em...guess were all fucked You might be a Redneck if you use your leftover gutters for a speaker box port... YOU JUST LOST THE GAMER.I.P. Blazer=========================Last setup was in the 141s on music (37hz) with 2 12s and 1kw in a 4dr blazer.2010 Mitsubishi Lancer DE2 12in Clarions (kept from blazer)HiFonics BRZ1700.1d (at 2 ohms BLOWN) [JBL GTS180X for subs currently 60wRMS x2ch!!!!!! This works for till i get the blown amp fixed] Alpine 4ch salvaged from blazer (currently near death)9887 peerless 7s in the doors and CDT tweeters ran active no speakers in the rearKintik HC1400 under the hood.metered once a while ago, dont remember it...was piss poor compared to the blazer, mid 130s i think....looking to replace subs and amp when i have money.
bkolfo4 Posted June 19, 2009 Report Posted June 19, 2009 When you T the 4" wide port against the back wall, make each side only 2" wide. The effective length of the port down the center of the box, including the 90 degree bends is roughly equal to the external depth of the box. The remaining length applies to BOTH sides of the T along the rear wall. Example - If you have a box that is 22" deep and you need a port 4" wide and 30" long: Run the center port walls into the box until they are 2" from the back wall. Add an additional port wall on BOTH sides parallel to the back wall, 2" wide x 8" long. Brian Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
siucsaluki11 Posted June 19, 2009 Author Report Posted June 19, 2009 thats what i was thinkin but i wasnt sure, ive never had to do a port like that yet woman..cant live with em...cant shoot em...guess were all fucked You might be a Redneck if you use your leftover gutters for a speaker box port... YOU JUST LOST THE GAMER.I.P. Blazer=========================Last setup was in the 141s on music (37hz) with 2 12s and 1kw in a 4dr blazer.2010 Mitsubishi Lancer DE2 12in Clarions (kept from blazer)HiFonics BRZ1700.1d (at 2 ohms BLOWN) [JBL GTS180X for subs currently 60wRMS x2ch!!!!!! This works for till i get the blown amp fixed] Alpine 4ch salvaged from blazer (currently near death)9887 peerless 7s in the doors and CDT tweeters ran active no speakers in the rearKintik HC1400 under the hood.metered once a while ago, dont remember it...was piss poor compared to the blazer, mid 130s i think....looking to replace subs and amp when i have money.
