sharkcity408 Posted June 19, 2009 Report Posted June 19, 2009 I want to build a wall box for my 06 dodge stratus.. I've built a couple boxes but nothing this big so I want to do it right. Ok My measurements of my backseat area is 48w x 37h x 32 d and I put it on 12volt.com and there saying I have almost 30 cubic feet of room! is that right? the btl's only need 10cubic feet each max.. But the other thing thats messing me up is the sub displacement and port.. can you guys help me out? http://www.the12volt.com/caraudio/boxcalcs.asp Heres the specs on the fi's too.. BTL18 DUAL 1 | DUAL 2 Fs: 31.9 Hz | 31.1 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 6.26 | 6.42 Qes: .26 | .24 Qts: .24 | .023 Mms: 313g | 329g Sd: 1210cm^2 | 1210cm^2 Vas: 163.1 l | 163.1 l Spl: 94.9dB 1W/1m | 94.9dB 1W/1m Bl: 18.3 N/A | 27.2 N/A Xmax: 28mm * | 28mm * Rms: 2000W * | 2000W * Sealed box: N/A cuft | N/A cuft Ported box: 5-10cuft | 5-10cuft Sub OD: 18.500” | 18.500” Cut ID: 16.750” | 16.750” Mounting depth: 10.250” | 10.250” Displacement: 0.26cuft | 0.26cuft Thanks !
Gotloud555 Posted June 20, 2009 Report Posted June 20, 2009 Use the subwoofertools.com YOu can also try the Math formula on realmofexcursion. Either both way.
