kfx450r Posted June 21, 2009 Report Posted June 21, 2009 Well my trucks gonna need a new battery soon, and since im looking forward to a big build I wanna make sure i put in something good. Well ive found a buncha kinetik hc600s for good prices (2 of em for less than 1 yellowtop) and noticed that I can fit 2x hc600s side by side in my battery tray under my hood and 2 produce more amps than a hc1400. So would this be a good idea to put 2x hc600s under my hood as my "mains" ? The back will most likly have a hc3800. Also if I was to do this..can I run the ground from 1 battery to the chassis and just run a ground from 1 600 to the 600 thats grounded? And like I said..I can get 2x hc600s for less than a 1200 or 1400 and produce more amps. Dont even think a 1400 would fit.
soundzright Posted June 22, 2009 Report Posted June 22, 2009 Well my trucks gonna need a new battery soon, and since im looking forward to a big build I wanna make sure i put in something good. Well ive found a buncha kinetik hc600s for good prices (2 of em for less than 1 yellowtop) and noticed that I can fit 2x hc600s side by side in my battery tray under my hood and 2 produce more amps than a hc1400. So would this be a good idea to put 2x hc600s under my hood as my "mains" ? The back will most likly have a hc3800.Also if I was to do this..can I run the ground from 1 battery to the chassis and just run a ground from 1 600 to the 600 thats grounded? And like I said..I can get 2x hc600s for less than a 1200 or 1400 and produce more amps. Dont even think a 1400 would fit. The 1200 or 1400 would kill 2 600's on reserve
kfx450r Posted June 22, 2009 Author Report Posted June 22, 2009 The 1200 or 1400 would kill 2 600's on reserve If u dont mind explaining what exactly does reserve do? I assumed its like when the cars off..how long itll play music for?
soundzright Posted June 22, 2009 Report Posted June 22, 2009 If u dont mind explaining what exactly does reserve do? I assumed its like when the cars off..how long itll play music for? That and when you are really hammering on the system there is more time to beat on the system if that is what you are doing. 2 600s are good for 1200 watts total where the 1200 is good for 1200 watts and more reserve and the 1400 is 1400 watts....
kfx450r Posted June 22, 2009 Author Report Posted June 22, 2009 That and when you are really hammering on the system there is more time to beat on the system if that is what you are doing. 2 600s are good for 1200 watts total where the 1200 is good for 1200 watts and more reserve and the 1400 is 1400 watts.... Hm..well I never play my system with my truck off..and the specs say that 2x 600s have way more amps than a single 1200 or 1400.
