Alpine Type R Dual 4ohm ..... 12"
nyd40cal
I am using a Rockford Fosgate P5002 and I have it bridged and it dosent seem to be that powerful.
mabe just a shitty sub and amp, but I think its just the wrong amp for it.
can I run a 1000watt amp to it? it is a dual 4ohm so how would I wire it up and what amp will push this thing to maximum capability ?
Might have something to do with the fact that you've got your amp bridged into 2 ohms...
x2, not many 2 channel amps are stable at 2 ohms.
run each coil to each channel, and TUNE THE GAINS THE SAME unless you want a blown sub.
could be your enclosure is the problem.
I am going to try running each coil to each channel. its not the encloser, Its the same cubic ft that was recommended for that sub.
I only bridge it cause I want the most power I get get from the amp..........It does knock , but i think it can do more.
if I run each coil to seperate channels, it will be the same watts, just different ohms CORRECT>?
  • Who's Online   2 Members, 0 Anonymous, 9148 Guests (See full list)
