Amp4 Components
zack74562
I Need help on knowing if the power of this amplifier will handle two component sets. Sorry I'm ust getting into car sounds and I need a lot to learn. If it doesn't handle the power then any suggestions on a amplifier i should get?
JL Audio’s HD 600/4 AMPLIFIER
Rated Power (4 Channel Mode): 150 W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (Bridged to 2 Channel): 300 W RMS x 2 @ 3 ohm-8 ohm (11V-14.5V)
THD at Rated Power: <0.03% @ 4 ohm per ch.
S/N Ratio: >110 dB below rated power
(A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 6 Hz - 30 kHz (+0, -1dB)
Damping Factor: >300 @ 4 ohm per ch. / 50 Hz
>150 @ 2 ohm per ch. / 50 Hz
Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions (L x W x H): 10.74 in. x 8.29 in. x 1.93 in.
273 mm x 211 mm x 49 mm
(Width Measurement Includes Plugs)
JL Audio’s COMPONENT SPEAKER SET
Description: Evolution™ ZR 6.50 in. / 165 mm 2-Way Component Systems:
6.50 in. / 165 mm Woofers; 1.0 in. / 25 mm Aluminum Dome Tweeters
This new range of reference component systems fully demonstrates JL Audio’s obsession with accurate sound reproduction.
Woofers: Custom-engineered, proprietary cast aluminum woofer baskets were designed to provide maximum rear open area while also incorporating JL Audio’s patented “Elevated Frame” cooling system. This cooling technology, shared with JL Audio’s W7 subwoofers, allows air to flow directly across the top-plate and onto the voice coil windings to greatly improve linearity at all listening levels.
Tweeters: 1.0 in. / 25 mm aluminum dome tweeter
Crossover Networks: All of these quality components are enclosed in a newly designed, polycarbonate case with a classy metal “ZR” logo that will look at home in any high-end installation.
Continuous Power Handling: 85 Watts
Peak Music Power: 255 Watts
Rec. Power Range (per channel): 25 - 175 Watts
System Efficiency: 89.5 dB @ 1W/1m
System Nominal Impedance: 4 ohms
System Frequency Response: 48 Hz - 25 KHz ± 3 dB
THANKS A LOT!
First of all do you have your mind set on JL ZR Components?
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Well, the reason why I was planning to go with this is because I thought I ust go with the same brand with what I got right now 2 13w7 and 2 1000 1v2. aren't they good component speakers??
They're decent component speakers...however there's a lot of better speakers out there in that price range, for example Focal, and Hertz. For the price you can get a lot better sound quality, and a speaker that will take the power of the HD600/4 a lot better than the ZR series.
Current Systems:
2011 BMW 335i
Hertz HDP1
2002 Acura Tl
Kenwood DNX9980HD
DC 3.5k
Hertz HDP4 Amp
  • Who's Online   0 Members, 0 Anonymous, 764 Guests (See full list)
