what i would do is wire 2 sets (4 speakers) to make 2 ohms and connect that to the amp. then connect the other 2 speakers as 4 ohm.
edit: (if this is wrong, please correct me)
Edited by enemyofsilence
Team Bass-Hz
# Super Sport AT 4-Channel Class A/B Car Amplifier
# RMS Power Rating:
* 4 ohms: 150 watts x 4 chan.
* 2 ohms: 300 watts x 4 chan.
* Bridged, 4 ohms: 600 watts x 2 chan.
# Max power output: 1200 watts
# Twin coil MOSFET auto step power supply
# Bass Remote Details (example 1: Wired remote bass level control included. example 2: Remote bass level input (remote level control sold separately)
# LED power and protect indicators
# Bass Boost/EQ (0-12 dB bass boost at 45 Hz)
# 2/1 channel operation
# Speaker-level inputs with signal sensing for automatic turn-on
# Preamp RCA outputs
# Pro-Fi MOSFET outputs
# 4-Way System Protection circuitry (DC, thermal, overload, and speaker short protection)
# Soft start turn-on
# Heavy duty aluminum alloy heatsink for extreme heat dissipation
# Silver-plated RCA level inputs
# Silver-plated screw terminals
# Variable high-pass filter (60-1,200 Hz, 12 dB/octave)
# Variable low-pass filter (30-250 Hz, 24 dB/octave)
# Damping Factor: >200
# Frequency response: 30-1200 Hz
# Dimensions: 10-1/4"L x 9-7/8"W x 2-1/16"H
# 4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
# (AT-1200)
Specs I was able to pull... I don't think it does rated power output though. With two 4 ohm speakers on each channel it says it's 300 watts a channel at 2 ohm which would be toooooooooooooooooooonns of power IF it does rated output. If your speakers are 8 ohm speakers two to each channel would =4 ohms like stated above. 4 ohm at two per channel would mean 2ohms... Match it up with manufactures spec on your speakers and see what works best for you
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
# RMS Power Rating:
# (AT-1200)
here are the speakers im gettin Selenium 6W4P 6" Woofer... dont kno what kind of tweeters to go with them yet
so u wanna run 8 speakers total?
6 mids and 2 tweeters?
Head Unit: Pioneer Premier Deh-600ub
Front Stage: (2) Whip Audio 8" Mid-Bass (2) Whip Auido 6" Mid & (2) Audiopipe ATX-3720
Amps: (2) Cadence TXA300-4 :D
Amp Kit: Knukonceptz
Coming Soon: already ordered
Sub: 2 DD T1508's
Amp: Sundown saz-1500
Tired of the lag? Come get crunk!
