K DUB Posted June 24, 2009 Report Posted June 24, 2009 i just bought a autotek 1200 watt amp an was lookin at pushin four , 6" Selenium speakers an two tweeters if possible... if i can, how do i go about doin this? please help!!!!! Quote
MATTMAN24 Posted June 24, 2009 Report Posted June 24, 2009 u running an active setup? Quote HIDS and projector headlights forsale http://www.stevemeadedesigns.com/board/topic/99528-hid-projector-headlights-and-hid-kit-look/ 24's and Tires forsale http://www.stevemeadedesigns.com/board/topic/100286-24s-with-tires-for-sale-east-texas/
enemyofsilence Posted June 24, 2009 Report Posted June 24, 2009 (edited) you can hook up two sets of speakers together to make a 2ohm load and connect it to the amp edit: i cant spell lol Edited June 24, 2009 by enemyofsilence Quote Team Bass-Hz
will77530 Posted June 24, 2009 Report Posted June 24, 2009 u running an active setup? just make sure the wattage is right and all you do is split the wires so that they are goining to both speakers its kind of hard to explain but you run the wire to the amp normally and then you go to about the middle of the wire you just ran and splice it hook up another wire to your splice and your good Quote
K DUB Posted June 24, 2009 Author Report Posted June 24, 2009 u running an active setup? yea active Quote
_AnGeL_ Posted June 24, 2009 Report Posted June 24, 2009 most 4 channels are 2 ohm stable per channel, that being said you can run either 2 4ohm speakers per channel, or 4 8ohm speaker per channel..... the wattage will be divided by the number of speakers. Quote Head Unit: Pioneer Premier Deh-600ub Front Stage: (2) Whip Audio 8" Mid-Bass (2) Whip Auido 6" Mid & (2) Audiopipe ATX-3720 Amps: (2) Cadence TXA300-4 Amp Kit: Knukonceptz Coming Soon: already ordered Sub: 2 DD T1508's Amp: Sundown saz-1500 Tired of the lag? Come get crunk!
Soulman07 Posted June 24, 2009 Report Posted June 24, 2009 Yeah, be careful with the tweeters though. I've popped a few at 2ohms in the past. Make sure you put some kind of bass blocker on them otherwise they might give. Quote 1993 Chevrolet SWB Pickup Viper 791XV Primer Stage 5/8 Static Drop Kinetik HC1800 Big 3 Knu Flex 0 Team Tex Flex
K DUB Posted June 24, 2009 Author Report Posted June 24, 2009 most 4 channels are 2 ohm stable per channel, that being said you can run either 2 4ohm speakers per channel, or 4 8ohm speaker per channel..... the wattage will be divided by the number of speakers. is 1.2khz good on a amp pushin highs Quote
Soulman07 Posted June 24, 2009 Report Posted June 24, 2009 Get the exact model of the amp and let us take a look at it Quote 1993 Chevrolet SWB Pickup Viper 791XV Primer Stage 5/8 Static Drop Kinetik HC1800 Big 3 Knu Flex 0 Team Tex Flex
enemyofsilence Posted June 24, 2009 Report Posted June 24, 2009 and what ohm are your speakers? they are prob 4 ohm (most cases) Quote Team Bass-Hz
