Need some Table Saw Help
I need to get a 60 degree angle. This is what it should look like
What the amps are on, I need at 60 degrees. My saw goes to 45, so idk how im going to accomplish this. Any ideas?
are you trying to cut the piece right under the amp
Edited by 87accord
new system in the works
(3) DC lvl 4xls 15's (one of three are here)
(2) DD z1 (done)
old kenwood four ch
4 runs of 2/0 (done)
? 200 amp alt may two ??
the only thing i can think of it cut it to 45 dreg and sand it the rest of the way but it late so brain is not all on
(2) DD z1 (done)
old kenwood four ch
It can be done but it's not for rookies
if I were u I would just cut the side pieces to
the angle you want then 30 deg the top plate and use a 1/2 roundover
will be nice looking on the top and sit at the correct angle
My design pretty much wont allow me to do that, my dad has been a woodworker for about 20 years and ill ask him, but i need to attach the sides while inside the car so i can run my wires to the amps. and so ill be able to screw the back of the rack into the back of my box. Ill have a build log if im not explaining it right.
ok i can think of only on other way i had to go look at my saw
tak a scrap piece of wood cut it at 30 dreg then take the piece you want for the amp borad that will give you the 60 dregs you need if you i can take some pic for you
(2) DD z1 (done)
old kenwood four ch
Thats what i thought but i have a vertical peice and that would only work for a horizontal piece or top plate, but i just dont have enough space. Cuz then i might as well use a 45 degree angle.
  • Who's Online   0 Members, 0 Anonymous, 397 Guests (See full list)
