well i have my a pillars all fiberglassed up and now its time for the body filler. does anyone have any tips that might help me out before i get started this afternoon? thanks in advance
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
Don't use bondo. Use something like evercoat, and use a good glaze.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
have everything prepared before you mix in the hardener, you will only have a few minutes to work with it before it becomes un-workable. also there is a "green stage" when its curing in which it is easiest to sand (where it is hardened enough to sand, but hasnt fully hardened. this will save you alot of sanding later on lol)
head unit - Panasonic MXE CQ-C7403U
amp - Cerwin-Vega EXL 1200D
subs - (x2) Cerwin Vega V-MAX 15.4
box - 5.8 ^3 at 32hz
spkrs- Phoenix Gold Rsd Comps
is bondo absolutly no good? i ask because i already have it, but if not then i guess ill try something else. can the evercoat be bought at a auto parts store.
d(-__-)b
I cant compare it to anything else first hand, but I've used bondo on several occasions with no ill-effects (door-pods, body work, pillers, sub boxes)
if you still have some resin mix a little bit in with your filler it will be easier to smooth out.
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
My 2 cents....
Work in small amounts, that way there will be little waste. And when everyone say it will only be a minute or two before it is unworkable they are not joking. So try small amount to start with to see how well you work with it and go from there.
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
Its very "unique" to work with, (if you havent worked with it before) like you'll mix it up and be spreading it out, then almost instantly it will just hit this stage where becomes unworkable. you'll have maybe 5 minutes at most. like sodfamily said, only mix small portions at a time so your not left with a bucket of hardened bondo lol
finally a question to which I have an answer since i run a bodyshop.. If you want something that is great then use rage gold it is a superior "bondo" that will sand nicely and have minimal pinholes if you need something cheaper most part store sell bondo which is ok but not the greatest if you want something that is better try your local auto body paint store we have alot in my area you should have a few, icing is good for final coats.so is metal glaze if you use less hardener it will stay workable for a longer period but will be runny depending on the humidity
when u mix it scoop it up and push down and keep doin that till its mixed. keeps the air bubbles out
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
