zack74562 Posted June 30, 2009 Report Posted June 30, 2009 I need some help on which amplifier should i go with for these focal speakers. Rockford T800/4 ?? or Rockford T1000/4 ?? to power (2) Focal Component 165 K3P sets Depth from wall : 77mm (3") Cut-out diameter : 142mm (5.6") Voice coil : 40mm (1.6") Magnet : 100mm (4") Woofer : Midrange: 165mm (6.5"), K2 composite sandwich cone - Woofer: 165mm (6.5"), K2 composite sandwich cone Tweeter : TN 52, Tioxid 5 inverted dome Nominal impedance : 4 Ohms (mid high) / 2 Ohms (mid flat) Frequency response (+/-3dB) : 60Hz - 22kHz Sensitivity (2.83V/1m) : 95.5dB Nom. power : 200W Max. power : 400W Product type : 3 way kit Controls : Tweeter level (0/+7dB per step of 1dB); midrange (mid flat/ mid high)
IH8PunkRok Posted June 30, 2009 Report Posted June 30, 2009 if u have 4 of them go with the 800/4 no need to overpower those speakers -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
*1LOWSUV* Posted June 30, 2009 Report Posted June 30, 2009 I have a T800.4 running 1-set of RF Power Coaxials, 2-sets of RF Power 4X6's and 3-sets of RF Power Comps...(3-speakers per channel) and its more then enough power. : [email protected]
