_AnGeL_ Posted June 30, 2009 Report Posted June 30, 2009 how would one go about doing this? Hu is a pioneer deh 600ub i will be running a 8" mid bass, 6" mid and a tweeter per door amp would probably be a mb quart dsc 4125 for mid bass/mid and a small amp for tweeters so im guessing i would probably have to buy a seperate xover to go 3 way active correct??? also what would be a good starting point as far a crossing over midbass, mid range and tweets? hope someone could help me out Head Unit: Pioneer Premier Deh-600ub Front Stage: (2) Whip Audio 8" Mid-Bass (2) Whip Auido 6" Mid & (2) Audiopipe ATX-3720 Amps: (2) Cadence TXA300-4 Amp Kit: Knukonceptz Coming Soon: already ordered Sub: 2 DD T1508's Amp: Sundown saz-1500 Tired of the lag? Come get crunk!
Boon Posted July 1, 2009 Report Posted July 1, 2009 Unless you buy higher end SQ amps with in-built crossovers to ~5k then you'll need another crossover. I would probably go ~300hz and ~3.7khz depending on the drivers you're using. 6" mid paired with a 8" mightn't be ideal, you really want a lighter-weight driver like a 3-4" dome driver to handle the mids, also makes it easier to mount up high with your tweeter to bring the soundstage up. 10.x volts fo' life!
Ray Posted July 1, 2009 Report Posted July 1, 2009 8 from 70-220@ 18db 6 1/2 from 180-2.7k @24db tweet from 2.7k up @ 18db just what id do. just get a really good tweeter 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Boon Posted July 1, 2009 Report Posted July 1, 2009 A really REALLY good tweeter but I agree, the lower you can pull your tweeter point the better it tends to sound. Large format tweeters for the win here If only the RF360.2 could do it, the only way it can is with mono'd midbass running off the center channel 10.x volts fo' life!
Ray Posted July 1, 2009 Report Posted July 1, 2009 I cut my hertz tweets at 1.3k@48db with 140 rms class a lol. I love the sound down there but get multiple imaging points most mid level tweets will hang at 2.2k ie: focal tn52 Mille 280's for the best image they should be crossed at 3k for most installs but with 3way I think he'd be fine at 2.4-2.5 ish running a small mid will help too 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
_AnGeL_ Posted July 1, 2009 Author Report Posted July 1, 2009 thanks for the info guys, as far as an external xover which one would you guys recommend (one that wont break the bank ) Head Unit: Pioneer Premier Deh-600ub Front Stage: (2) Whip Audio 8" Mid-Bass (2) Whip Auido 6" Mid & (2) Audiopipe ATX-3720 Amps: (2) Cadence TXA300-4 Amp Kit: Knukonceptz Coming Soon: already ordered Sub: 2 DD T1508's Amp: Sundown saz-1500 Tired of the lag? Come get crunk!
_AnGeL_ Posted July 7, 2009 Author Report Posted July 7, 2009 bump.... whats a good external crossover that will let me run a 3-way active fronstage?? Head Unit: Pioneer Premier Deh-600ub Front Stage: (2) Whip Audio 8" Mid-Bass (2) Whip Auido 6" Mid & (2) Audiopipe ATX-3720 Amps: (2) Cadence TXA300-4 Amp Kit: Knukonceptz Coming Soon: already ordered Sub: 2 DD T1508's Amp: Sundown saz-1500 Tired of the lag? Come get crunk!
