CR Boom Posted July 4, 2009 Report Posted July 4, 2009 Does anyone know if it is ok to bend a V-belt backwards, like a serpentine? like when installing a idler, to get proper belt wrap... 2007 Great Wall So Cool 4-12' RE audio MX's Stetsom 7k2D 6-Batts 3-Mechman 250 amp Rhino's
E a r t h Posted July 4, 2009 Report Posted July 4, 2009 i wouldnt advise it, but if you have extras readily available to you, you could possibly get away with it in a temp application or quick short term use with fresh belts. i wouldnt trust it for an everyday daily driver though, that belt would start coming apart
CR Boom Posted July 4, 2009 Author Report Posted July 4, 2009 When I added the 3 alt. I had to put a idler in at the crank to get my belt wrap back on the crank. and my belts are now cranked on the teeth side. I just wondered if I got some bad belts? 2007 Great Wall So Cool 4-12' RE audio MX's Stetsom 7k2D 6-Batts 3-Mechman 250 amp Rhino's
E a r t h Posted July 5, 2009 Report Posted July 5, 2009 you mean cracked? not the belts fault, you just need a serpentine system yeah v belts arent designed to bend that way, hence the cracking and possible chunking if left long in that arrangement
