Alternative power supply?
Yo! :yahoo:
I know you can use a computer power supply to run a car amplifier in your house, but can you use other power supplys than that, for example is it possible to use the power supply from a microwave oven or the vacuum cleaner instead of a computer power supply to run the car amplifier.
Personally i dont see a problem as long as the voltage is right etc etc.
Is it possible? im just curious :pardon:
I'm not an expert but I think current is the biggest issue and 2nd would probly be ah shit I just forgot the word, in long, some of those power supplies might induce noise into what you want to use.
EDIT: filter- filtered output
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
LOL just save up and do it rite.
My test bench.
and a nice little temperary setup for the shop while I'm doing my install.
Samlex Power Supply 23 amps continue-us (can't spell) around $100 and has been great.
^^^ Yep, thats the way to do it
I was on a job site where a "engineer" thought we could use power supplies to run these 60amp 12v DC servo motors
I laughed at him, those computer power supplies are good for 5amp and under I believe, but with some big amperage, its all about batteries, and battery chargers
We found a 60amp 12v power supply that we wired to 1 battery, and 1 supply, to 2 of these motors, just turned one on at a time, and eventually had 4 motors running on 2 batteries, and 2 supplies
(motors were 60amp peak, 20amp continuous use after warm up)
