Mounting Amp To Box
CHINO11550
I have no room so i am bolting my amp to my box is there anything i can put between the two to stop or help with vibration
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
Is your box covered in carpet?
SUCCESS is a decision, NOT a dream. You have to name the price you are willing to pay to get it.
"You didn't have an ice pick on you? Amateur. " -- Wax from Fchat.
The front is, not the back where the amp is going to be
MLA module 15+volts
Team Bass Hz
You could try that covering it in carpet like that, I put my amp on my carpeted box with 2 12's and it didn't rattle around.
get a bicycle tire and cut a bunch of 1"x1" squares and put those between the amp and box. rubber spacers work too
but if at all possible don't mount the amp to the box.
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
I have no ckoice
MLA module 15+volts
Team Bass Hz
Nice idea, I never woulda thought of that.
When I have no choice but to mount an amp to an enclosure, I use strips of styrofoam between the amp and the box. You can cut them small enough to be invisible, but keep that amp's chassis off of the box itself. Also, use 1 small rubber washer on each screw holding the amp down.
Thanks guy, just went to pick up some thick rubber sheets from work
MLA module 15+volts
Team Bass Hz
  • Who's Online   0 Members, 0 Anonymous, 690 Guests (See full list)
