i used dupont chromabase primer and paint and clear coat.. all came out perfect while doing the bupmer but i got some pimples in the clear coat and i would like advice on how to fix that without haveing to spray more clearcoat.. times are tight..
its very lil pimples. about 25-30 but spread in groups of 3-4 around the bupmer.. i gave more then enough flash time between coats of clear..
how do i fix it. what grade sand paper and do i use soapy water to wet sand...?
4 15'' kicker L7 subs ( only 2 being used right now )
1 kicker zx2500.1 ( another soon 2 come )
box is 9.5 cubic feet slot portd thur the back seat
1 kicker zx650.4 amp powering 4 10'' ev dl10x mids ( rear deck )
1 kicker zx350.4 power 4 8'' beyma 8mi100 mid/highs ( 1 on each door )
2 runs of zero gauge wire ( about 60 feet total. )
big 3 done in zero gauge kicker wire
3 runs of 4 gauge for voice amps and eq' and crossover
2 kinetik hc1800 batteries in the trunk and 1 optima yellow top under the hood
260 amp irragi high output alternator ( soon to be 2 alt's )
alpine cda 9856 ipod headunit
kicker kx3 3 way crossover & a old school alpine 3342 digital 11 band sound field processor eq.
( search for ( 88bonnsse ) on youtube.com to see my videos..
i would say use some 2000grit and wetsand.... ive never used soap... so idk
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Vehicle: 2003 Lincoln Navigator
Exterior:Custome Air bags, Chrome Grill, 8000K Hid Low & Fogs, 24in rims,Corsa dB Performance Exhaust
Amplifiers:Kicker Kx2500.1, MA Audio M700XE
Batteries: 1 Kinetic Hc2400 Battery
Electrical: STOCK Charging System! Tsunami 40farad Capacitor,
Enclosure: 8 ft³ tuned to 45Hz Interchangeable Ports(34Hz)
Headunit: STOCK! (DVD,CD,Navigation), AudioControl LC6i, AudioControl Epicenter
Mids/Highs: (4)Sets Of Focal Access Component 690 CA1, 2) Sets Of Infinity Reference Tweeter
Subwoofers: 2) 15 Power Acoustik Mofo
Wire: Multiple Runs Of 1/0 Gauge Streetwire Cable
Video: http://www.youtube.com/2treo15
http://www.stevemeadedesigns.com/board/ind...showtopic=45762
You don't use soap, you add soap to your water while your sanding as it gives the sanding a lil more slickness while sanding.
I fill a spray bottle with water, then add a few drops of soap and shake it up.
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
  • Who's Online   0 Members, 0 Anonymous, 689 Guests (See full list)
