Can I hook my Power wire up to my alternator?
So, my question is, Can i hook my amplifier power wire up to my alternator directly?
i drive a 2002 dodge neon, Im pretty sure it has an external reg. So if i did hook it up with my power
wire direct to the alt. What would happen? With an externally regulated alt, IS voltage be "Decided"
at the B+ terminal of the alt, or AT the external reg?
I dont want to chance having my amps F**k up because i hooked them up to the alternator.
(also, if it helps, there is a bettery in my trunk separating the alternator, the power wire, and my D-Block.)
So is this safe?
So is this safe?
No you need to have a battery between your alternator and you amplifier.....your alternator doesnt put out all that amperage in a flat curve...it ripple charges and bad things will happen if you do decide to try it.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
Sweet. Thats very helpful. So i have a separate bettery in my trunk, which is fused 3 times before it touches my amps. That should work excellent. But what about the regulator thing? Is the voltage decided allready when the electricity leaves the alternator? Or is it decided AFTER it leaves? Kinda like a power inverter deal.
  • Who's Online   1 Member, 0 Anonymous, 1163 Guests (See full list)
