4 channel amp SOLD and 2 door speakers $40 + shipping
2 of the speakers
Posted Image
Pioneer Premier TS-A702C components
$40 plus shipping
6-3/4" (oversized 6-1/2") A-Series Component System
Power Handling:
Peak: 460 watts per set / 230 watts each side
RMS: 100 watts per set / 50 watts each side
Composite injection molded polypropylene cone with interlaced Aramid Fiber woofer
Butyl rubber surround
7/8" Tetron Soft dome tweeter with magnetic fluid and neodymium magnet
2-Way external crossovers with low pass and high pass filter at 12 dB/octave
Surface, flush, or invisible tweeter mounting
Aramid fiber damper
Glass-Imide voice coil bobbin
4 ohms impedance
OFC Copper voice coil wire
Top-mount depth: 2-1/2"
there was a little damage on one of the door speakers i have fixed it and it still sounds great but it isnt the prettiest thing
The amp
Posted Image
Posted Image
Pioneer GM-6400F 4 Channel 600 Watts Car Amplifier
SOLD!!
•GM Series 4-Channel Class AB Car Amplifier
•RMS Power Rating:
◦4 ohms: 60 watts x 4 chan.
◦2 ohms: 75 watts x 4 chan.
◦Bridged, 4 ohms: 150 watts x 2 chan.
•Max power output: 600 watts
•PWM Regulated MOSFET power supply
•LED power indicators
•4/3/2 channel operation
•Built-in crossover LPF/HPF (front/rear independent)
•Variable high-pass filter (cut off frequency: 80 Hz, -12 dB/octave)
•Variable low-pass filter (cut off frequency: 80 Hz, -12 dB/octave)
•Built-in speaker level inputs
•Hi-volt (400mV ~ 6.5v) input level control
•Exclusive H shaped chassis and heatsink
•Gain control caution feature helps prevent damage to speakers
•CEA-2006 compliant amplifier
•Frequency response: 10-50,000 Hz
•Dimensions: 8-1/2"L x 2-1/2"W x 13-5/8"H
everything has only been used for about two weeks have the boxes for everything but one pair of speakers
i am selling this stuff because i am picking up a chrystler new yorker this week :yahoo: and decided to go with a whole different set up
will have more pictures up soon
you might want to consider making your pictures larger. People would really like to see the condition of the said items.
I love my staffie :good:
So anti FACEBOOK it isn't even funny
