Home audio build in room
ok guys, ive decided its time to work on my room a little now. so ive thought about doing a set up that can get pretty low for when i want to listen to my music, and sound good for when i decided to watch a movie in my room. im working with a space of 12x13ft so this set up should sound really good in this space. here is what im going to be doing.
two towers holding 2 10'' dayton subwoofer, 2 tang band mids, and 1 tweeter
center is 4 3'' mids, and 2 tweets
rear is going to be 1 3'' mid in a box. there will be two boxes
and i like to thank krannyman92 for the box design and sketch up for me
Posted Image
Posted Image
Posted Image (will be used in towers with subwoofers )
Posted Image
Posted Image (3'' mid going to be used for center channel and rear channel)
Posted Image
Posted Image (will power subwoofers)
Posted Image
Posted Image
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
nice set up, but I HONESTLY, would do a dipole design
I guarantee you will have better sound, and you will have a slicker design
W-M-T-M-W design will kick ass
whats a dipole design? and a W-M-T-M-W design would look cool but its all up to mike. it took us like 3-4 hours to figure everything out up to this point. so we gotta think more about this tomorrow. any advice is welcome
Ive done almost as much home audio as car audio, but I prefer home audio
Dipole designs mix the speakers up to give a more spacial sound, better imaging, more accurate design
http://images.google.com/imgres?imgurl=htt...N%26start%3D144
What the WMTMW means is
woofer bottom mid, then tweeter, then mid again, then back to woofer at top
I would try this , sit down in your favorite seat in the house, get a tape measure, and measure from the ground to your ear, and start with the tweeter in the dipole design at that height
It sounds almost to much to try that, but the higher frequencies are the hardest to please your ears, and the subsonic of course, but with tweeters, and upper midrange, they are very directional, so basically when you walk away, or turn your head, you really hear the difference.
So to start the whole tower speaker design, based solely where your ears are when you sit down in the room, is a great starting point
http://images.google.com/imgres?imgurl=htt...l%3Den%26sa%3DG
this is way over kill, but these speakers are just about the best in the world, and its not because the speakers inside the towers are just about the best, but its the angles, and distances from the speakers to your ears
check out the price, Iam not sure the euro to the dollar, but its way up there- well, I think its $160,000
Box V2, follows W-M-T-M-W configuration
Posted Image
the advise is great guys bc this is my first home audio build. im still trying to move everything around in my room, take things out and get it to where i know where my towers are going to go. then i will do the measure test for the tweeters. this is in a 12x13ft room, so its not like a big living room where this is going. ill have pics of the room up soon
1 3500d AQ amp
second design looks good, that open area in the back, perfect spot for the amplifier
just an example of the space this will be in.
Posted Image
Posted Image
Posted Image
Posted Image
the long dresser by the bed is going to be haled off, so that whole wall is free also.
1 3500d AQ amp
Posted Image
is that a bunch of little woofers? or r they ports
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
