alaskanbass Posted July 14, 2009 Report Posted July 14, 2009 i did this sketchup on google sketchup right and i was wonderin if anyone can help me out here.. im not totally sure on the measurements. its for 1 jl audio 8w3v3 single 4ohm eight. thanks in advance Quote clarion cz500 head unit Kinetik hc600 2 level 3 15s in a 4th order mb quart 1500.1 (for now untill i get a dc 1.2k) all knu konceptz wiring in a 2009 ford flex -DISKOLORED AUDIO- -Authorized Dealer for DC Soundlab in Alaska-
Forevrbumpn Posted July 14, 2009 Report Posted July 14, 2009 just by doing some simple math, I see its tuned around 38-40z, and the port area is a little tight for 1-8" @33sq inches might want to open up the line a little bit? what are the specs of the sub? Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
rckstar Posted July 14, 2009 Report Posted July 14, 2009 what does the length of the line work out to? Quote my motto: hit it, quit it, never admit it
alaskanbass Posted July 14, 2009 Author Report Posted July 14, 2009 the left side is the single 4ohm and the right side is the single 8ohm.. if any of that helps http://mobile.jlaudio.com/products_subs.php?series_id=27 Free Air Resonance (Fs): 35.14 Hz 35.40 Hz Electrical “Q” (Qes): 0.501 0.489 Mechanical “Q” (Qms): 7.071 6.789 Total Speaker “Q” (Qts): 0.467 0.456 Equivalent Compliance (Vas): 0.54 cu. ft. / 15.29 liters 0.57 cu. ft. / 16.14 liters One-Way, Linear Excursion (Xmax)*: 0.375 in. / 10.0 mm 0.375 in. / 10.0 mm Reference Efficiency (no): 0.127% 0.141% Efficiency (1W/1m)**: 83.24 dB SPL 83.68 dB SPL Effective Piston Area (Sd): 32.02 sq. in. / 0.021 sq. m. 32.02 sq. in. / 0.021 sq. m. DC Resistance (Re): 3.77 ohm 7.42 ohm Nominal Impedance (Znom): 4 ohm 8 ohm Thermal Power Handling (Pt): 250W 250W Driver Displacement: 0.03 cu. ft. / 0.85 liters 0.03 cu. ft. / 0.85 liters Net Weight: 8.2 lbs. / 3.7 kg 8.2 lbs. / 3.7 kg Quote clarion cz500 head unit Kinetik hc600 2 level 3 15s in a 4th order mb quart 1500.1 (for now untill i get a dc 1.2k) all knu konceptz wiring in a 2009 ford flex -DISKOLORED AUDIO- -Authorized Dealer for DC Soundlab in Alaska-
Forevrbumpn Posted July 14, 2009 Report Posted July 14, 2009 Okay, after reading the specs, your pretty much right on, but I feel it may be pretty punchy, quick bass, hard to tell because of the Q factors but 1 thing, if your sub has 1-8ohm coil, and 1 4ohm coil, dude, something is wrong there Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
kirill007 Posted July 14, 2009 Report Posted July 14, 2009 you know you need to invert the sub, right? Because the mounting depth is 4.63 inch. , and the port is 4 inch. Quote Thinking is the root of all problems... You ALWAYS get what you pay for.
rckstar Posted July 14, 2009 Report Posted July 14, 2009 I think the spec he gave is for the 4ohm model and 8 ohm model, thats why theres 2 Q factors and everything else Quote my motto: hit it, quit it, never admit it
Forevrbumpn Posted July 14, 2009 Report Posted July 14, 2009 I think the spec he gave is for the 4ohm model and 8 ohm model, thats why theres 2 Q factors and everything else I noticed, but still very close As far as mounting depth goes, I'am sure he will be using 0.75" MDF or Ply so there will be a little room behind the motor Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
kirill007 Posted July 14, 2009 Report Posted July 14, 2009 forgot the wood. Quote Thinking is the root of all problems... You ALWAYS get what you pay for.
alaskanbass Posted July 15, 2009 Author Report Posted July 15, 2009 thanks for the input guys .. ima have to put my subs up for sale now.. and eventually step it up to larger subs someday.. Quote clarion cz500 head unit Kinetik hc600 2 level 3 15s in a 4th order mb quart 1500.1 (for now untill i get a dc 1.2k) all knu konceptz wiring in a 2009 ford flex -DISKOLORED AUDIO- -Authorized Dealer for DC Soundlab in Alaska-
