tline help
i did this sketchup on google sketchup right and i was wonderin if anyone can help me out here.. im not totally sure on the measurements. its for 1 jl audio 8w3v3 single 4ohm eight. thanks in advance
clarion cz500 head unit
Kinetik hc600
2 level 3 15s in a 4th order
mb quart 1500.1 (for now untill i get a dc 1.2k)
all knu konceptz wiring
in a 2009 ford flex
-DISKOLORED AUDIO-
-Authorized Dealer for DC Soundlab in Alaska-
just by doing some simple math, I see its tuned around 38-40z, and the port area is a little tight for 1-8" @33sq inches
might want to open up the line a little bit?
what are the specs of the sub?
the left side is the single 4ohm and the right side is the single 8ohm.. if any of that helps
http://mobile.jlaudio.com/products_subs.php?series_id=27
Free Air Resonance (Fs): 35.14 Hz 35.40 Hz
Electrical “Q” (Qes): 0.501 0.489
Mechanical “Q” (Qms): 7.071 6.789
Total Speaker “Q” (Qts): 0.467 0.456
Equivalent Compliance (Vas): 0.54 cu. ft. / 15.29 liters 0.57 cu. ft. / 16.14 liters
One-Way, Linear Excursion (Xmax)*: 0.375 in. / 10.0 mm 0.375 in. / 10.0 mm
Reference Efficiency (no): 0.127% 0.141%
Efficiency (1W/1m)**: 83.24 dB SPL 83.68 dB SPL
Effective Piston Area (Sd): 32.02 sq. in. / 0.021 sq. m. 32.02 sq. in. / 0.021 sq. m.
DC Resistance (Re): 3.77 ohm 7.42 ohm
Nominal Impedance (Znom): 4 ohm 8 ohm
Thermal Power Handling (Pt): 250W 250W
Driver Displacement: 0.03 cu. ft. / 0.85 liters 0.03 cu. ft. / 0.85 liters
Net Weight: 8.2 lbs. / 3.7 kg 8.2 lbs. / 3.7 kg
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
Okay, after reading the specs, your pretty much right on, but I feel it may be pretty punchy, quick bass, hard to tell because of the Q factors
but 1 thing, if your sub has 1-8ohm coil, and 1 4ohm coil, dude, something is wrong there
I think the spec he gave is for the 4ohm model and 8 ohm model, thats why theres 2 Q factors and everything else
I noticed, but still very close
As far as mounting depth goes, I'am sure he will be using 0.75" MDF or Ply
so there will be a little room behind the motor
thanks for the input guys .. ima have to put my subs up for sale now.. and eventually step it up to larger subs someday..
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
  • Who's Online   0 Members, 0 Anonymous, 1455 Guests (See full list)
