OBI Posted July 15, 2009 Report Posted July 15, 2009 Where do you guys usually put ours at? Just wondering, never used one before.
97maxima Posted July 15, 2009 Report Posted July 15, 2009 put were?? you mean were the wire is ran??? or what its hooked to??/ please be a little more detailed American Bass*DC Power
white4d96 Posted July 15, 2009 Report Posted July 15, 2009 The blue remote wire going to an amp? There should be a blue wire coming off your HU harness labeled "remote" or "rem" or something similar. Or wire it to the batt with a switch if you have a stock HU (I know there are other solutions but I can't think of them right now.) Basically it sends 12 volts to your amp to tell it to turn on. EDIT: as for running it, I ran it with my RCA's on the right side of my car under the carpet. Too many projects, too little time...
OBI Posted July 15, 2009 Author Report Posted July 15, 2009 Sorry i should been more detailed but I know where the wires go. I just need ideas on where I could mount it to.
Neel Posted July 15, 2009 Report Posted July 15, 2009 I usually run the remote line with the power lines. It really doesnt matter , just make sure that you run it carefully and securely to avoid it getting damaged (like any other wire that you run in your car...). Too Much Stuff to list .
brewer_brewer Posted July 15, 2009 Report Posted July 15, 2009 I usually run the remote line with the power lines. It really doesnt matter , just make sure that you run it carefully and securely to avoid it getting damaged (like any other wire that you run in your car...). i hook all of my remotes to my ignition with a toggle switch inline with it so that anytime my ignition is on the amp is unless i have the toggle switch flipped. REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
