Did the shop try a new head unit? Do you have the noise with an mp3 player hooked up in the rcas going to the eq/amps?
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
had noise with 3 different headunits hooked in the car
no noise when i ran the eq off the ipod on aux bypassing the headunit. one other thing is i think my radio is touching the firewall behind it it reall isnt any room behind it the factory radio is smaller than aftermarket and not as deep
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
thanxs for all the help
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
hooked up my ground loop isolater. took away the noise and my midbass so i took it right out .
grounded my h/u and eq and relay with a 12g wire all to the same spot. (still noise ) straight bare metal frame
replaced all the rca in the (car still noise)
im fuckin stumped!!!!
i figure it is the eq itself or the amp or the head unit that is bad . im thinking it is the eq that is bad it is the cheapest piece in my system.
ill try bypassing it tommorrow if that aint it im going back to my factory radio and factory speakers and just be pissed everyday cause it not loud enough .
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
Have you tried running from the HU to the amp without plugging into the EQ?
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
yeah i had just a little noise that way
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
to check if your HU is bad try this. Wire the remote turn on to the accessory wire in your harness, wire up a mp3 player right to the RCAs, and if there's no noise, it's your HU.
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
i also remember the only difference from before when i didnt have noice before i took my system out was the antennae plug. i did not have it hooked up because i do not listen to the radio. now i have it hooked up could this be the problem? could that bring noise into the h/u even if its not on tuner
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
any other suggestions guys
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
  • Who's Online   1 Member, 0 Anonymous, 3583 Guests (See full list)
