nathan664 Posted July 16, 2009 Report Posted July 16, 2009 Hey guys what is clipping? Is it just not tuned right or not alot of power to the amp? not to sure please help.
jizzybizzy Posted July 16, 2009 Report Posted July 16, 2009 Hey guys what is clipping? Is it just not tuned right or not alot of power to the amp? not to sure please help. clipping occurs when an amp is requested to produce more output voltage than it has the capacity to do so you ain't been bizzy til you've been wit jizzy. Vehicle:: 2005 Saturn Ion Headunit:: Jensen 9312HD Speakers:: RE SE Coaxials Subwoofer(s):: (2) 15" RE SEs Amplifier(s):: Audiopipe AP1500.1D Audiopipe AP1504 Enclosure:: Sealed Wire: KNU KONCEPTZ 1/0 Battery:: Kinetik HC600
bumonskateboard6 Posted July 16, 2009 Report Posted July 16, 2009 Clipping is when the magical amp fairies are all on the toilet and when they flush out comes a huge turd that burns your coils. EDIT: Also it's when the sine waves of music which are normally curved in shape become flattened at the top and bottom waves because either the song was recorded and edited clipped, or the amplifier does not have the incoming voltage to produce the outgoing voltage to your woofers/speakers. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
dred Posted July 16, 2009 Report Posted July 16, 2009 Watch the vidz: name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>"> name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
