ok this sounds dumb but i can take without crying
im getting ready to run my power wire to the back of my car (2+ 2- in 2/0awg) and need to know what size fuse i should run for the battery
i will have two interstate SRM-4D in the back what size fuse would be needed
here are the spec on the battery if it is needed
cca 1314 Reserve Capacity Min. @ 25A 390min
thanks for the help guy i just dont want my car up in flames
oh im running two dd z1 and a kenwood 4ch
Edited by 87accord
new system in the works
(3) DC lvl 4xls 15's (one of three are here)
(2) DD z1 (done)
old kenwood four ch
4 runs of 2/0 (done)
? 200 amp alt may two ??
300 amps on each amp so 600 + 80 for the kenwood i think
sorry at work dont have the amps here
(2) DD z1 (done)
old kenwood four ch
:help: anyone? do you need more info? any rule of thumb?
(2) DD z1 (done)
old kenwood four ch
ok i think i might have found my answer here it goes since i am running 2/0 i should have a 400 amp fuse up front then another 400amp fuse in the rear right before the battery and a 300amp fuse for each amp
since my amps are dual power and ground inputs i should have a 150 amp fuse on each input totaling 300amps right?
so this would be the lay out
alt----[200amp fuse]------battery------[400 amp fuse]------[400ampfuse]--battery---[300amp fuse]--amp
Edited by 87accord
(2) DD z1 (done)
old kenwood four ch
im getting ready to run my power wire to the back of my car (2+ 2- in 2/0) and need to know what size fuse i should run for the battery
For 2ga wire you should use either between 200-250a fuse, anything within that range will do.
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
your 2ga wire is very highly unlikely to carry 400a of current, especially at that distance, I'd imagine the wire would catch fire before that much power was carried across it. The whole point of fusing that lead is to prevent fires. I'd suggest a 250a fuse max for 2ga wire.
the wire i have is 00awg i though it was 2/0 but i might be wrong
ok just looked it up and yes it is 2/0awg wire or 00
not 2awg so would i be correct with using a 300 amp fuse since that is all i can find
Edited by 87accord
(2) DD z1 (done)
old kenwood four ch
before going any further, find out what size your wire is
ok hold on yes the wire is 2/0
Edited by 87accord
(2) DD z1 (done)
old kenwood four ch
  • Who's Online   0 Members, 0 Anonymous, 3517 Guests (See full list)
