Any box builders?
k3n12ock
http://www.stevemeadedesigns.com/board/ind...st&p=701186
Please help. I'm thinkin gabout going 3 or 4 of these, which ever I can save trunk space with (most likely the three). I need help building a box as I have no kind of box building skills other than the RE Calc. in which It won't be any good. I would say maximum dimensions for the box could be 42Lx18hx20w
Subs:
http://www.dealercostcaraudio.com/ts-w1007d2.aspx
Specs:
Woofer Cone Material Composite IMPP Cone using Interlaced Aramid Fiber
Woofer Cone Design Cone Reinforcement Arcs
Surround Wide Roll, Three-Layer Fiber Woven Radial
Voice Coil 4-Layer, Long Voice Coil
Voice Coil Wire Copper
Voice Coil Bobbin Phenol Resin Coated Glass Cloth
Damper (Spider) Aramid Fiber
Damper Ring Yes
Top Plate Standard
Projected Pole Yoke with Vented Pole Yes
Magnet Construction Double Mass High-Power (74oz)
Basket Design Stamped Basket with Magnet Cover
Gasket Molded
Wire Terminals Integrated Single-Sided Silver Compression Terminals
Specifications
Watts MAX. Music Power 1000 Watts
Watts Nominal Power Handling 350 Watts
Frequency Response 18 Hz to 600 Hz
Sensitivity 87dB
Ohm Rating D2 (2 ohm) D4 (4 ohm)
Recommended Enclosure 0.65 ~ 1.25 Cubic Feet
Dimensions 277 mm x 162 mm
Mounting Depth 143 mm
i can make somethin up for ya also, for a small fee
  • Who's Online   1 Member, 0 Anonymous, 2887 Guests (See full list)
